    Project wall cabinet with hdmi monitor
    wall cabinet
    3 Posts 3 Posters 1.7k Views
    • najaruN
      najaru
      Hello
      Actually I have a simple RPi3 with retropie installed, working on a 43" lcd TV
      all work good, but not very functional.....
      My project is to do a "modular" wall cabinet, in 2 different phases. I want to do by step because i'm not very familiar with electronic component and programming
      STEP 1 - RPi3 + little 4:3 LCD HDMI monitor + wireless pad. RPi powered by USB out monitor
      STEP 2 - custom joypad x 2 player in additional wall structure (that will be "attached" in bottom of first structure)
      similar example all in one
      your advice?
        backstander @najaru
        @najaru
        Sound like fun!
        Typically these USB outs on TVs don't push enough power and the USB outs on monitors aren't powered and needs another cable to plugs into a computer where it gets power and may not be enough power. There might be a few rare monitors/TVs that push enough power. Just keeps this in mind when building.
        I would recommend a powered hub that could also be used to power the RPi and have it so you can access 1 or 2 of the USB ports from the outside of this cabinet for accessories.
        • DipkidD
          Dipkid
          Good project, just dig in! its very fulfilling when it comes together.
          Heres a pic of my half cab / wall-cade, inspired by the same polycade you linked.
          Its runs a raspberry 3b with AM, generic pc speakers, a hdmi 19" screen, usb led-lights and double dragonrise usb-pcb´s.
          I made the plans in Illustrator and built it at work with our cnc-table.
          really only got two good tips;
          1. buy a multi outlet with a couple usb sockets. I draw the power to the lights and the speakers from there, so the raspberry dosent overcook.
          2. If youre green on linux/mame etc; Read the Retropie-wikis, watch lots of youtube! :)
          RetroPC: https://retropie.org.uk/forum/topic/13048/the-1976-retropc-diy-retro-gaming-computer-build
          Wallcab: https://retropie.org.uk/forum/topic/28324/wall-mounted-cab-2-0
          Candy Cab: https://retropie.org.uk/forum/topic/34290/diy-candy-cab-arcade
