    System title text in System view
    system viewtext editortitle
    5 Posts 3 Posters 1.2k Views
    • paffleyP
      paffley
      Hi, is there a way to display the system name in the system view?
      • funkybunchF
        funkybunch
        You can do that by editing the theme. Uncomment the logo file and set parameters for the font (i think it is possible). I prefer to make a custom theme from sketch or the easiest way: make custom logos with only the name of the system as a .png file ;-)
        • paffleyP
          paffley
          Hi, thanks funkybunch...
          I'm already using the logo for my theme and I understand that if you remove the logo then the title text will appear in place. I was just wanting to know if there was a variable for the title text available, no problem tho, I'll just use an image object instead (with some text).
          Thanks again, much appreciated :)
          • mattrixkM
            mattrixk @paffley
            @paffley Instead of adding an extra <image>, you could add an extra <text> field:
            <text name="system_name" extra="true">
              <text >Super Nintendo</text >
              <pos>x x</pos>
              <size>x x</size>
              <fontPath>./font.tff</fontPath>
            </text >
            • paffleyP
              paffley
              @mattrixk Perfect thank you!
