    Retropie 3.7 and LXDE LAN trouble
    2 Posts 1 Posters 716 Views
    • CybermenC
      Cybermen
      Hi, I have installed on the Retropie Setup LXDE . It works like everything, but I have no LAN connection more . Or rather no IP address more Raspberry PI 3. If I leave Emulation Station and am in the command prompt , he shows up at yes always , wievel GB is free , the temperature from the PI and the IP address . There is now but nothing more , so I can not access my PC on it. anyone know the problem or has a solution ? About advice I would be very grateful .
      • CybermenC
        Cybermen
        Hello, I have solved the Problem. In order to add a permanent IP Adress, you will Need to amend the cmdline.txt file inside the boot Directory. Type the following:
        sudo nano /boot/cmdline.txt
        Add the following text add the very end of the Code string:
        ip=192.168.0.28
        Remember to add 1 space before "ip" - you can also use 192.168.0.28 if you want. Exit the file by pressing CTRL+X, save by pressing Y, and Exit by pressing ENTER.
