    No Sound anymore
    3 Posts 3 Posters 999 Views
      DeadIntermediate
      I have changed the output to my hdmi and I am still not getting any sound? Any advice of tips?
      iconrumbleI 1 Reply Last reply Reply Quote 0
      • O
        opensourcefan
        Help us help you - https://retropie.org.uk/forum/topic/3/read-this-first
        Aside from the missing details above... I'm assuming you've had sound working nicely for a long time and all of a sudden, without any provocation it just stopped? I'm new at this so the first thing I would do is reboot. Then in all seriousness I would check the obvious such as my volume, my speaker cable and/or plugs. Try another output and eliminate either the pi or the external device.
        RPI3, v 3.7 from SD Image, Last update, Bluetooth v1.0, Child-Friendly ES, 3 amp Power Supply, Case w/fan.
        • iconrumbleI
          iconrumble @DeadIntermediate
          @DeadIntermediate As @opensourcefan said, we need more details about your problem...
          Have you checked the wiki? https://github.com/RetroPie/RetroPie-Setup/wiki/Sound-Issues
          Did you google it?
          https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=147533
          https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=103773
