    Retropie Jamma Cabinet Credits
    mamecreditsjamma
    2 Posts 2 Posters 1.2k Views
    • N
      neox666x
      Hi
      I'm using a pi with Retropi in a original jamma Cabinet.
      Is there a way to use the original Credit Board from the Cabinet? I Can use 2 pcb and switch from One to the other. In mame game it Works fine if you Not in game it will Not get the credits . And if yup go to another game tze credits are lost. Is there a way to fix it?
      Thx for help
      • simonsterS
        simonster
        I don't think so. Each arcade machine in MAME is emulated individually and effectively thinks it is a separate cabinet.
        Maybe if you can explain how you are using it and for what purpose, someone may be able to give a little more help.
