    Zaxxon audio
    advmamezaxxon
    38 Posts 5 Posters 15.2k Views
    • AlexMurphyA
      AlexMurphy Banned @caver01
      @caver01 Thanks, no they are the same .wav files. zaxxon.zip is the exact same size. It's a head scratcher but no massive deal as I said it runs perfectly on advmame and that's good enough for me. Cheers for the help.
      • chipsnblipC
        chipsnblip
        repacking the zip archive might help in this case
        • caver01C
          caver01
          Weird. I don't know why I thought the numbers were different!
          What about updated binaries? I know the sample path changed, but that was a while ago.
          • AlexMurphyA
            @caver01 I'm all up to date. Thanks again, don't worry about it. No big deal as advMame runs it perfectly. You seem to be fretting over this more than I ever did!
              stevep @caver01
              @caver01 Here is some screenshots of advmame setup:
              0_1495481806526_advmame.PNG 0_1495482115644_advame2.PNG ![0_1495482194901_advmame3.PNG](/forum/assets/uploads/files/1495481714818-advmame3-resized.png
              Still not working but plays fine on my pc. I'd appreciate you taking a look see. I think everything is in the right folders.
                stevep
                Here is the config file .It didn't upload with my last message0_1495482500386_advmame3.PNG
                • AlexMurphyA
                  AlexMurphy Banned @stevep
                  @stevep Create a file called samples or re-name the one you have called "sample" or change the file path in the config to point to the correct directory.
                  EDIT: I see it is . But try changing every thing to "samples" mine works like that.
                  • AlexMurphyA
                    @stevep Which advMame are you using? Just asking. There are 3.
                      stevep
                      I have all 3 but I'm currently working with 1.4
                      • AlexMurphyA
                        @stevep Are you sure you are running them with 1.4 because you may not be.
                          stevep
                          Yes...I don't quite follow your last post .The rc file reads
                          dir_sample /home/pi/RetroPie/roms/mame-advmame/sample
                          That's where I put them...also when I open the emulator on retropie it tells me I have a game called sample....
                          AlexMurphyA caver01C 3 Replies Last reply Reply Quote 0
                          • AlexMurphyA
                            @stevep okay, You are editing the 1.4 rc file. Are you using 1.4?
                            • caver01C
                              caver01 @stevep
                              @stevep You have the files in the correct place as far as I can see. It does not have to be plural "samples", it just has to match the path that is listed in the .rc file. Make sure you are launching with 1.4. Then, check your sample file size. It may differ from the one we have been talking about above, since the romset for advmame is different.
                              • caver01C
                                caver01 @stevep
                                @stevep do you also have
                                sound_samples yes
                                in your .rc file?
                                • caver01C
                                  caver01 @AlexMurphy
                                  @AlexMurphy said in Zaxxon audio:
                                  @caver01 Thanks for the offer. I have this 710 KB (727,146 bytes) and there are 12 .wav files inside. It's named correctly zaxxon.zip and it's in ...BIOS/mame2003/samples/ It's from the 0.78 set. Samples is set to ONCan't figure out the issue at all.
                                  It just doesn't feel nice to leave a stone unturned. . . I know we keep bouncing back and forth between advmame and mame2003 comments, but for lr-mame2003, when you said Samples is set to ON are you referring to the libretro core option mame2003-samples? I think the valid value for this should be enabled. Just a thought.
                                  AlexMurphyA 1 Reply Last reply Reply Quote 1
                                  • AlexMurphyA
                                    @caver01 Holy shit. You are obsessed with my 0.78 Zaxxon! If you are ever in Belfast, Ireland let me know! You have a place to stay. Hahaahahhaaha!
                                    • caver01C
                                      caver01 @AlexMurphy
                                      @AlexMurphy Ha ha. Well, not really obsessed. It's just a puzzle. There is obviously some reason I can get the audio to work in 2003 and you cannot. I am curious if any samples work for you in this emu, or if it is just zaxxon. But if you don't want help I guess we can forget about it. I am going to chalk it up as something strange on your end ;-).
                                      • AlexMurphyA
                                        @caver01 I really appreciate how helpful you have been. I just don't want to waste your time.
