    NES30 Pro with 3.7 on Pi3 - Paired but not working in ES or Retroarch
    2 Posts 2 Posters 889 Views
      PJROUSE
      Setup - Pi3 with vanilla install of 3.7
      NES30 Pro running 1.68 firmware
      Using a usb keyboard I can get the NES30 Pro to pair successfully using the bluetooth setup but when I go back into ES, the pad does nothing at all.
      If I run the "Configure Input" wizard and hold a key on the pad it's not detected.
      If I drop out of ES and run jstest it shows JS0 and detects inputs so it is working and is paired?
      No idea why ES wont detect it
      Works fine if I plug in via USB cable as well
      es_input.cfg is here - http://pastebin.com/FhXb29VT
      retroarch.cfg is here - http://pastebin.com/gUm1hP7L
      Pls help
      Paul
      FloobF 1 Reply Last reply Reply Quote 0
      • FloobF
        Floob @PJROUSE
        @PJROUSE Did you create the file mentioned in the Wiki?
        https://github.com/RetroPie/RetroPie-Setup/wiki/Setting-up-a-Bluetooth-controller#this-section-is-for-jessie-based-retropie-version-34-and-later
