    Scraper collects images but dumps them in the wrong directory, images are not shown for roms
    scraper problem
    3 Posts 1 Posters 773 Views
    • E
      enduranceman
      So the title pretty much. I ran the following command for scraper on my system
      # scraper -add_not_found true -append true -console_img "mix3,3b,b" -console_src "ss,ovgdb,gdb" -image_dir "/opt/retropie/configs/all/emulationstation/downloaded_images/nes" -image_path "/opt/retropie/configs/all/emulationstation/gamelists/nes" -img_workers 4 -max_height 600 -missing "/opt/retropie/configs/all/emulationstation/gamelists/nes/missing.txt" -retries 2 -rom_dir "/home/pi/RetroPie/roms/nes/" -rom_path "/home/pi/RetroPie/roms/nes/" -ss_password "REMOVED_OBVIOUSLY" -ss_username "REMOVED_OBVIOUSLY" -workers 4
      Looking over it I already see some errors, but interestingly it didn't dump the images in my intended target location OR the location actually specified in -image_dir. Instead it dumped all the images in a NEW directory it created at /home/pi/images
      Looking at these images, it also downloaded the standard 2d boxart, last in my list of preferred source images below a mix and 3-d boxart.
      I am using the standard nointro NES romset, so these are not obscure titles.
      What is wrong with my command?
      • E
        enduranceman
        I believe I may have found the issue with my command. The output of scraper -help shows flags in the following format:
        -image_dir directory
        The directory to place downloaded images to locally. (default "images")
        I believe this SHOULD be input as -image_dir="directory" rather than -image_dir "directory"
        I'm running the command again with an = between flags and contents, this is now collecting the correct type of image and placing it in the proper location. This still doesn't explain why the images weren't visible after a reboot once the scraper had finished before with the wrong command though. Any idea why that might be?
        • E
          enduranceman
          For anyone that stumbles upon this post in the future, the fix was to delete all instances of gamelist.xml (can be found by issuing sudo find / -name gamelist.xml), the downloaded images sudo rm -fv ~/.emulationstation/downloaded_images/nes/*, and then ran the command again.
