    Where and how do I look for runcommand.log? so I can look for errors
    runcommandiconsfolder pathfile locationsnoob
    2 Posts 2 Posters 1.7k Views
    • SonPluckS
      SonPluck
      I have no Idea how look for the runcommand.log, so I can look at errors, I already tried to look for the files (over network) didn't find anything... tried to run it trough terminal, that also didn't work...
      I also tried to look for the icons folder the same way, no luck.
      Do I remove my sd card and see my files through the computer? I don't know... rip
        meleu @SonPluck
        @SonPluck /dev/shm/runcommand.log
        It won't work if you remove the SD to plug in another computer because files under /dev/shm are RAM based, which means that they only exist while the raspi is on.
