    Help with controller figuration..
    retropiesetup
    4 Posts 3 Posters 897 Views
      retropiejay
      Hi guys, fairly new with setting up retropie, haven't even put an ROMs on my RP3 yet. Let me tell you what happened. I got as far as setting up my controller (ps3 plugged in USB) and went to try to bluetooth it and screen froze and i did a hard reset (pulled the plug). Now i rebooted my pie and the controller configuration screen won't pop up anymore and i can't use my Ps3 controller. Only thing i can do is use my keyboard. Is there any way to bring the controller figuration screen back up? with just the keyboard or is there a way to use my ps3 controller?
      • caver01C
        caver01 @retropiejay
        @retropiejay if you can figure out what key to press to bring up the Emulation Station menu, there is an option to configure controllers. However, it sounded like you froze during Bluetooth setup. Might be time to read through the steps for that and try again. Freezing is not normal. Could be you have a bad SD card or corruption. If you haven't even setup ROMs yet, I might suggest a fresh re image just to be sure.
        Next time you post a question, please provide the details about your setup as required in THIS POST.
        • AlexMurphyA
          AlexMurphy Banned @caver01
          @caver01 How can I get Virtua Fighter 4to run on my Samsung Microwave? And by the way, why doesn't RetroPie come pre-installed on my Tumble Dryer? That's what I want to know!
          • caver01C
            caver01 @AlexMurphy
            @AlexMurphy did you even try to use google first? Sheesh.
