Idea: Carousel Scrolling Sound & Back Sound
I wanted to add some sounds to my Switch theme, I currently have 3:
- back.wav
- scroll.wav
- select.wav
I wanted these sounds to play at their respective times. "Scroll.wav" would play when selecting a system on the carousel as well as in the gamelist. The sound will only play when added to the textlist code. But crashes the theme when added under carousel.
Similarly, I wanted "back.wav" to play when going back to the system select from the gamelist, but that doesn't work. "Select.wav" works fine when choosing a game.
Could sound support be added for the carousel and as an exit sound?
@lilbud
If I recall I read somewhere that these were partially coded in before ES was abandoned.I may be entirely wrong though.
I agree that these additions would really appreciated.
@Syhles That's a shame, but the game select sound and gamelist scrolling sounds play, but carousel scrolling and exiting a menu are silent.
@lilbud this is not terribly difficult to implement, I'd say go ahead and create a new issue on the tracker, so that developers can pick it up when they want to.
It's a good project for someone to get started, as you probably can just follow the same approach as currently implemented for the gamelist scrolling and launch sounds.Thanks for bringing this up!
@Zigurana I added it on the ES repository.
