    Roms won´t start - strange problem
    romtelevisionoutputstartpi3
    27 Posts 5 Posters 10.7k Views
      pjft @Dlay
      @Dlay I wouldn't say it's time to give up yet.
      Where do you set the option to launch it at boot? As I said I don't know enough about auto start. Is there a set of other services or commands you're running there? Maybe one is taking hold of the console.
      Can you share the list of services/commands you're running and then testing removing them one by one to see if we narrow it down?
      Then maybe it's easier to search for how to mitigate that.
        Dlay
        You can set it in Retropie-Setup
        Under C - Configuration / tools
        then 802 - autostart
        then 1 - Start Emulation Station at boot
          mediamogul Global Moderator @Dlay
          @Dlay
          If you would, post the contents of /etc/emulationstation/es_systems.cfg.
          Edit: Nevermind. I had a idea, but your error makes it unlikely.
          Edit 2: A listing of your services and commands would indeed be helpful.
            Dlay
            what do you mean with services and commands ?
            cyperghostC mediamogulM 2 Replies Last reply Reply Quote 0
              cyperghost @Dlay
              @Dlay
              service --status-all
                @Dlay
                Since you've installed RetroPie over an existing system that was originally tasked with other purposes, a list of running services or commands launched at startup might shed some light on the issue and any conflicts that may exist.
                Running services can be discovered with:
                As noted above. Also, an alternative is:
                systemctl list-unit-files | grep enabled
                And you should check /etc/rc.local for launch commands.
                  Dlay
                  [ + ] acpid
                  [ + ] alsa-utils
                  [ - ] anacron
                  [ - ] asplashscreen
                  [ + ] avahi-daemon
                  [ + ] bluetooth
                  [ - ] bootlogs
                  [ - ] bootmisc.sh
                  [ - ] checkfs.sh
                  [ - ] checkroot-bootclean.sh
                  [ - ] checkroot.sh
                  [ + ] clamav-daemon
                  [ + ] clamav-freshclam
                  [ + ] collectd
                  [ + ] console-setup
                  [ + ] cpufrequtils
                  [ + ] cron
                  [ + ] dbus
                  [ + ] dhcpcd
                  [ + ] dphys-swapfile
                  [ + ] fake-hwclock
                  [ + ] fhem
                  [ + ] hdparm
                  [ - ] hostname.sh
                  [ - ] hwclock.sh
                  [ + ] kbd
                  [ + ] keyboard-setup
                  [ - ] killprocs
                  [ + ] kmod
                  [ + ] loadcpufreq
                  [ - ] lvm2
                  [ - ] mdadm
                  [ + ] mdadm-raid
                  [ - ] mdadm-waitidle
                  [ + ] minidlna
                  [ + ] monit
                  [ - ] motd
                  [ - ] mountall-bootclean.sh
                  [ - ] mountall.sh
                  [ - ] mountdevsubfs.sh
                  [ - ] mountkernfs.sh
                  [ - ] mountnfs-bootclean.sh
                  [ - ] mountnfs.sh
                  [ + ] networking
                  [ - ] nfs-common
                  [ + ] nfs-kernel-server
                  [ + ] nginx
                  [ + ] nmbd
                  [ + ] ntp
                  [ + ] php5-fpm
                  [ - ] plymouth
                  [ - ] plymouth-log
                  [ - ] postfix
                  [ + ] procps
                  [ + ] proftpd
                  [ + ] quota
                  [ - ] quotarpc
                  [ + ] raspi-config
                  [ + ] rc.local
                  [ + ] resolvconf
                  [ - ] rmnologin
                  [ + ] rpcbind
                  [ + ] rrdcached
                  [ - ] rsync
                  [ + ] rsyslog
                  [ + ] samba
                  [ + ] samba-ad-dc
                  [ - ] saned
                  [ - ] screen-cleanup
                  [ - ] sendsigs
                  [ + ] smartmontools
                  [ + ] smbd
                  [ + ] snmpd
                  [ + ] ssh
                  [ - ] sudo
                  [ + ] triggerhappy
                  [ + ] udev
                  [ + ] udev-finish
                  [ - ] umountfs
                  [ - ] umountnfs.sh
                  [ - ] umountroot
                  [ + ] urandom
                  [ - ] watchdog
                  [ - ] wd_keepalive
                  [ - ] x11-common
