    First post about RetroPie
    retropie 4.2.2controllermap
    26 Posts 7 Posters 7.2k Views
      RpiBeginner
      Yeah thats what I think too. Uhm. btw.. Do you know how to setup the PSP emulator so it runs games like little big planet more smoothly? Its pretty laggy on my pi3, but I've seen a youtuber play it silky smooth.
      • ExarKunIvE
        ExarKunIv @RpiBeginner
        @RpiBeginner
        that i have not figured out yet, i know that you just need to play with the settings, but what i do not know
          RpiBeginner
          Overclocking? I tried fiddling around with this in retropie setup, but it told me that pi3 cannot be overclocked..
          On a more positive note though, I've read many places that N64 games almost can't run. I experience the exact opposite. I have a bunch of them and they all work :)
            edmaul69 @RpiBeginner
            @RpiBeginner just wanted to let you know about dosbox controls. You want to hook up a mouse and keyboard as well. When you start a game and you get into the game press ctrl & f1 together. It will bring up a hard to see blue on black menu. If you click on something you want to configure a key to you then want to click on the add button at the bottom. Then click on the controller button or joystick direction you want to add. Set up an exit button. I forget what it is called in the config, but its right under player 1. I use my select button for exit. Set up player 1 and player 2 both on player 1's controller. That will give you 4 buttons and two analogs if your controller has it. Any extra buttons you can program to keyboard keys. I program my start button to escape. If you want to know anything about setting up .sh files to be able to automatically boot straight to a game and have it running at the correct speed or how to best set up your dosbox config file i will gladly tell you everything you need or want to know. Same with setting up .sh files for zdoom if you choose to use that for doom engine games. It is far better than lr-prboom and you can run tons of games and mods on it. I have all dos doom engine games on both dos and zdoom. Sometimes i like to play them old school. I have 50+ doom engine games running on zdoom
              RpiBeginner
              @chien-dinh
              @chien-dinh said in First post about RetroPie:
              Unfortunately using the built in settings for Little Big Planet you may see a slight performance boost. To get it running smoothly you need to refer to this - See Overclock
              Hi again.
              Okay so today I tried to overclock my RPI3.. But I don't think I'm doing it right.
              So I've read the link you posted, and here's what I did:
              First I put my SD card in my pc and opened the Config.txt file and changed the default value for Arm freq (700) to 800. with no noticeable change.
              Then I tried inserting core_freq and gpu_freq and gave them the same values as the link suggests. Still No noticeable increase in performance what so ever?
              I've tested Tekken 5 (PSP) because it was laggy and GPU heavy..
              I've also tested Super smash bros (N64) because the sound was bugging out. No difference in both games.
              So I might be doing this wrong, could you help me please?
                barrymossel
                You could try this tutorial (at own risk): http://www.instructables.com/id/RetroPie-Overclocked-Raspberry-Pi-3-for-Video-Game/
