    Retropie doesn't work
    ineedhelpretroitdoesnotworkcanyouhelpme hd
    5 Posts 2 Posters 729 Views
      sepedro77
      I have a Raspberry Pi3 and I just downloaded Retropie and once that it was installed and i already configurated the controller my current at home switched off so the Raspberry Pi suddenly turned off. Now I just turned it on again and Retropie isn't working, my screen is black. What can I do??
      • simonsterS
        simonster
        Hi @sepedro77
        I would recommend that you reinstall the software to the SD card. It sounds like the card has become corrupt. I know you say the power went off in this case, but try to make sure you shutdown properly from the menu.
        Please make sure when posting a support request, you complete the information requested in https://retropie.org.uk/forum/topic/3/read-this-first
          sepedro77
          Oh sorry I was so worried that I didn't see anything, thank you very much. May I ask how can I re-install it? should I delete all of the files and then format?
          • simonsterS
            simonster
            You need to rewrite the image to the SD, it shouldn't necessarily need to be reformatted. Win32DiskImager writes the whole device when you use it.
              sepedro77
              Thank you very much. I will try now.
