Hum noise on Retropie
Hi!
I have problems with noise on the TV when running Retropie. Watch the movie under to see how it is. Its a noise when i am in the menu or a game. It is not there when i am in text based mode, like the audio setup menu. The noise was there the first time i booted the pi with the Retropie sd card. I have tried to set this in /boot/config.txt:
hdmi_drive=2
hdmi_force_hotplug=1
hdmi_force_edid_audio=1
disable_audio_dither=1I am using a LG tv via HDMI. The noise is gone when i switch to the 3,5 mm jack on the pi.
I am using a Raspberry Pi 3, official Pi powersupply, and have also testet an other powersupply i am using on a other Pi. Tested both HDMI ports om my tv. Running Retropie version 4.2 (latest). Everything else runs just fine, all games work an graphics is just fine.
Video:
I hope somebody can help, i realy want sound in my games! :)
@rolvs have you tried a different hdmi cable? A different hdmi port? A different tv?
I have testet an other port, but i have not testet a other HDMI cable. I will try that! I just have one TV (!!!) so i cant test it now, but i will try the cable.
@edmaul69 Sometimes the problems are easy to fix! I testet an other HDMI cable and it works perfect! TNX! :) Finaly i can play with sound!
@rolvs Hum noise is usually caused by poor Ground connection or shielding on the cable. In this case the HDMI cable that was replaced.
