Ugh Controlls messed up cant fix help?
Everything was working fine untill i reinstalled retropie now in getting all sorts of issues i cant seem to fix any way i configured my controllers but i accidently configured my keyboard first and then my bluetooth controller now the problem is when i play a game i cant start+select out of it nor get retroarch up but it does work with my keyboard i think i have it set so that my keyboard is player 1?
I know i can configure each controllers for each system in retroarch and i did that its set but still i cant start and select out of it with my controller other buttons work fine its probably because its player 2 i have no Idea how to fix this i tried googling it but i cant seem to find anything anyway how can i set it so my bluetooth pad is player 1 so i can start+select out of games? -
@retrofreak89 Please comply with this request so that we have a picture of your setup environment:
Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first -
@ortsac im not sure what you mean not sure what i need to post?
But it seems like my hotkeys are mapped to my keyboard as its player 1 i think but i want my controller to have it mapped so i can start and select out of games with my controller do you know how i can fix this? -
This is so frusterating i cant seem to map the hotkeys to exit emulators to my bluetooth controller because i think my keyboard is player 1 is there anyway to fix this im out of options dont know what to do now..
Sigh
I believe the hotkey will only work with player one. Just unplug your keyboard .
the keyboard will always be set as player one from what ive read. and it should work simultanously with the gamepad.
