    PSX multitap help
    multitap psx
    2 Posts 2 Posters 1.3k Views
      catastroph3
      Pi Model or other hardware: 3b (I think?)
      Power Supply used: 2.5a
      RetroPie Version Used 4.2
      Built From: Pre made SD Image on RetroPie
      USB Devices connected: 1 X PS4 control, 2 X Xbox 360 control wired, 1 X keyboard
      Controller used: see above
      Error messages received: n/a
      Guide used: n/a
      File: all roms
      Emulator: PSX default
      Attachment of config files:
      How to replicate the problem:
      Basically I'm trying to get the multitap option to work with 1 X PS4 controller and 2 X Xbox 360 controllers to play 3 player with 2 friends, all 3 controllers on emulation station are able to scroll and access the menus however when I enter game 3p is not recognised (tried with various roms) I have enabled the multitap options in retro arch config whilst in games and I have also enabled game specific configurations. The bios has been installed also, I'm pretty much computer illiterate so if anyone could help in simple terms it would be appreciated.
        edmaul69 @catastroph3
        @catastroph3 could be a couple issues. Are you using wireless 360 controllers? If so the wireless receiver is actually detected as 4 controllers so your other controller is probably detected as controller 5. You can use joystick-selection to change which controllers are used as what in retroarch systems. Is your psx emulator, lr-pcsx-rearmed?
        If so if you go into the retroarch gui by pressing select & x. Then go into quick menu then options. Now enable the multitap. Plus you might have to change each controller between standard and analog in there.
