    mintyPi Build
    mintypisudomodraspberry pi 0handheldbuild
    23 Posts 10 Posters 12.3k Views
    • N
      Natron @obsidianspider
      @obsidianspider Oh, sorry, I must have missed that. In that case, I would recommend not doing the acetone vapour bath. It can go wrong if you leave it in too long and become all gummy and ruined, and if you can't make another it could be risky. Still love that build, though, thanks for sharing it.
        obsidianspider @Natron
        @natron I'm really liking it. I'll just have to remember what it is when I'm playing it.
        • caver01C
          caver01 @obsidianspider
          @obsidianspider I suppose a smooth, injection molded part would not bind up the same, right? I wonder if there is a workaround for smoothing out this area such as a coating of epoxy or bondo that could be sanded nice and smooth without enlarging. Tedious and tiny, I know. Another thought would be to try a set of buttons you don’t care about and remove the orientation tabs. Maybe it’s the angled spots where the tabs are that bind up.
