    external hard drive question *SOLVED*
    questionexternal drivestorage
    3 Posts 2 Posters 918 Views
      time2purge
      i been using my 1tb hard drive for my roms on my pie and wanted to know, if i store other things files and music will it mess up the piroms folder,
        edmaul69 @time2purge
        @time2purge no. It is fine to mix and mingle.
          time2purge
          sweetness thanks for the answer
