Audio within 3.5mm
Please help. I made a portable arcade with the rasberri pi 3 and can't get the volume to be adjusted with the 3.5mm jack. I ordered an amplified plugin speaker but its way loud and I have no idea how to adjust the volume. Anyone help? Thanks
@kmetz7547 inside emulationstation, when you press start in the menu there are sound settings. Try adjusting it in there.
