    Reicast help
    reicast retopiereicast helpdreamcast help
    4 Posts 2 Posters 1.3k Views
    • EcksE
      Ecks
      Hi i am running RetroPie 4.2 everything is up to date and all so i thought i would try out some Dreamcast games since i got my new case with a tiny fan (cause i wanted to overclock) and also i am using a Pi 3 but after checking if Reicast was installed i started to load up some games to the system and yes i have the proper bios set up as well in my Pi but when i would do a reboot so everything would be loaded up the emulator doesn't show up in the list which i want to know if someone might have encountered this before and would give me some advice on what i should do.
      P.S. my Pi is overclocked to 1.3 GHz just in case someone wanted to ask what i have it at now.
        Aryetis @Ecks
        @ecks said in Reicast help:
        I'm pretty sure the bios wouldn't affect the listing of games within emulationstation. Let's get rid of the usual suspect first, what extensions are you using for your roms ? (reicast only supports .cdi or .gdi, NO .zip archive)
        EcksE 1 Reply Last reply Reply Quote 0
        • EcksE
          Ecks @Aryetis
          @aryetis I know the extensions and i only convert my games to CDI format (because even though i don't own a Dreamcast anymore i still own about 30 games)
            Aryetis @Ecks
            @ecks Did you test those files with some other emulators (eg: nullDC for pc) just to check their validity ?
