    ES Themes problem
    es themes downl
    10 Posts 4 Posters 2.7k Views
      buccs13
      Hi I have a raspberry Pi 3.
      I can't use a downloaded ES Themes. Everytime I download it and try to select it, I have a white screen as a themes. I don't have this problem with the basics themes.
      What can I do?
      My Retropie version is 4.2.16
      TMNTturtlguyT HurricaneFanH 2 Replies Last reply Reply Quote 0
      • TMNTturtlguyT
        TMNTturtlguy @buccs13
        @buccs13 what theme are you trying to run and what version of emulationstation are you running? The ES version is at the bottom of the menu when you press start.
        • HurricaneFanH
          HurricaneFan @buccs13
          @buccs13 Have you tweaked your vram settings?
            buccs13 @TMNTturtlguy
            @tmntturtlguy Nes-Mini Or Mario Blue
            I have version v2.1.5RP
              buccs13
              @hurricanefan No. How can I do that?
                buccs13
                The only one that is working that is not an original ES theme is Comic_book
                  buccs13 @HurricaneFan
                  @hurricanefan I juste check my vramit is at 100Mb and I tried200-300 and 400 no changes.
                  HurricaneFanH 1 Reply Last reply Reply Quote 0
                  • HurricaneFanH
                    @buccs13 I've seen some people have 80 and that seems to fix their theme issue.
                      jdrassa
                      You need to update EmulationStation. Both are taking advantage of some newer features that have been added to ES since the last RetroPie image was made.
                      You can update by launching RetroPie-Setup and then choosing
                      Manage Packages -> Manage core packages -> emulationstation
                      You should be fine to do the binary update.
                      Get latest build of EmulationStation for Windows here
                        buccs13 @jdrassa
                        @jdrassa thanks a lot it is now working.
                        you can close this post.
