    Retroflag NESPi Case - Soft Power & Reset Hack
    nespiretroflagsoft shutdowntutorial
    151 Posts 38 Posters 100.0k Views
    • YahmezY
      Yahmez @iLackIQ
      @ilackiq I'd be willing to bet that the traces are still connected, although you can not really tell one way or the other from your photo. Did you take photos of everything without all the tape on it? I can't really give any advice beyond what I have without seeing everything.
      • I
        iLackIQ @Yahmez
        @yahmez said in Retroflag NESPi Case - Soft Power & Reset Hack:
        https://imgur.com/a/mPjh4
        Album for them all
          snarc @iLackIQ
          @ilackiq
          Why is your orange cable connected to +5V of the fan?
          • I
            iLackIQ @snarc
            @snarc said in Retroflag NESPi Case - Soft Power & Reset Hack:
            @ilackiq
            What are you talking about? The only orange cable I used was connecting the two + pins on the switch board. There is another cable that looks orangesh-brown that I used to connect the switch board to the mosfet.
              snarc @iLackIQ
              I meant that picture: https://imgur.com/YygmAy3
              • I
                iLackIQ @snarc
                Oh that was the hardware test. It's been removed
                YahmezY 1 Reply Last reply Reply Quote 0
                • YahmezY
                  Yahmez @iLackIQ
                  @ilackiq try removing the pi completely. Nothing connected. Make sure the power switch is off, then plug in the power to the back of the case. Does the led come on?
                  • X
                    xman73
                    My reset button is isolated and NESPi turns on and off fine. Reset button is on GPIO 5 and grounded. After I installed the shutdown.py script (curl...|bash), my Retropie boots to the 4 raspberries and then shuts down. I tried to get it to boot in safe mode but can't get to a CLI. Any help is appreciated, thanks.
                    X 1 Reply Last reply Reply Quote 0
                    • X
                      xman73 @xman73
                      It was the wrong shutdown script that caused the shutdown on startup.
                      • E
                        elvycoll
                        @druz it is possible to replace the mosfet tcp8114 with another one more easy to find, actually I live in dominican republic here is really rare to find these spesific part, can you please help me
                          cyperghost @elvycoll
                          @elvycoll Consider to buy a NESPi+ case
                          Maybe you can buy a Pimoroni SHIM instead...
