    Will GZDoom Ever Come To Retropie????
    doom
    95 Posts 6 Posters 33.5k Views
      RetroFreak89 @edmaul69
      @edmaul69
      Well damn...
      Because that part with all the monsters lags bad
      And i also have it default when i play Valiant i dont change any diffeculty..
      Now in rly wondering why its running such crap can you check what fps u get at that spot?? Ill check the same..
        jcook84 @edmaul69
        @edmaul69
        this version: https://www.doomworld.com/idgames/levels/doom2/Ports/megawads/valiant
        I'm playing it on Zdoom, the Prboom test was just a tangent.
        At 640x480 I get dips into the teens at that rough part in the video (while spamming rockets) It's just a bad spot with lots of enemies spawning in and a long/complex render distance behind them. At 320x240 it dips into mid 20's at the problem spot. (stock clock and memsplit w/ fan)
        @Brigane
        I'm doing it the way the wiki suggests:
        https://github.com/retropie/retropie-setup/wiki/Doom#how-to-launch-doom-iwads-and-mods-pwads-from-emulationstation-using-zdoom
        edmaul69E R BriganeB 3 Replies Last reply Reply Quote 0
          edmaul69 @jcook84
          @jcook84 yeah if that date is correct i am definitely using that one. I am playing at 1024x768. I got a few dips in the teens today but i didnt experience any noticeable lag as they didnt last long enough to see slowdown.
            @edmaul69 hmm ill check in a min to see my fps there also stock and 640x reso
            Also whats the difference between prboom and zdoom does prboom play mods and wads as well??
              RetroFreak89 @jcook84
              @jcook84 So for you Valiant runs pretty crappy too some parts of the levels??
                edmaul69 @RetroFreak89
                @retrofreak89 no. Pr-boom plays doom games only.
                • BriganeB
                  Brigane @jcook84
                  @jcook84 Well.. The wiki suggest many different things depending on which iwads are used. Would you mind pasting the script here.
                  I got the other iwads working except valiant.wad
                  Systems: Raspberry Pi 0/2/3 Model B+
                  Os: RetroPie 4.5
                  Frontend: Emulationstation & Attract Mode
                    edmaul69 @Brigane
                    @brigane are you using gzdoom or zdoom?
                    BriganeB 1 Reply Last reply Reply Quote 0
                    • BriganeB
                      Brigane @edmaul69
                      @edmaul69
                      zdoom
                      Os: RetroPie 4.5
                        edmaul69 @Brigane
                        @brigane i will post the cofig when i get home
                          edmaul69 @Brigane
                          @brigane if you put doom2.wad and Valiant.wad (notice valiant has a capitol V as caps and lowercase have to match) in /home/pi/RetroPie/roms/ports/doom/ , then this would be the emulators.cfg for valiant
                          default = "zdoom"
                          zdoom = "/opt/retropie/ports/zdoom/zdoom -iwad /home/pi/RetroPie/roms/ports/doom/doom2.wad -file /home/pi/RetroPie/roms/ports/doom/Valiant.wad"
                          R BriganeB 2 Replies Last reply Reply Quote 1
                            @edmaul69 i wish i could figure out why my doom runs worse than yall lol
                            • BriganeB
                              Brigane @edmaul69
                              @edmaul69
                              Thanks, It runs quite well on my end, at least the first couple of minutes I've been trying it. I'm using an overclocked Raspberry Pi 2.
                              Edit: Now I also got trailblazer running. It's running pretty smooth imo
                              Os: RetroPie 4.5
                              • BriganeB
                                Brigane
                                Thought I'd would let you know I manage to setup Brutal Wolfenstein 3D as well by using the same method.
                                Os: RetroPie 4.5
                                  RetroFreak89 @Brigane
                                  @brigane omg omg how the hell did u get trailblazer running i cant get it to run it crash in load... Plz help?
                                  Also whats Ur fps on Valiant? Do vid_showfps true
                                  • BriganeB
                                    Brigane @RetroFreak89
                                    @retrofreak89
                                    I'm not quite sure how I show fps in-game. But please fill me in, if you do.
                                    This is how I got trailblazer working.
                                    this is my config in /opt/retropie/configs/ports/trailblazer/emulators.cfg
                                    zdoom = "/opt/retropie/ports/zdoom/zdoom +set fullscreen 1 -iwad /home/pi/RetroPie/roms/ports/doom/doom2.wad -file /home/pi/RetroPie/roms/ports/trailblazer/trailblazer.pk3"`
                                    default="zdoom"
                                    This is where I placed my wad file /home/pi/RetroPie/roms/ports/trailblazer/trailblazer.pk3
                                    My trailblazer.sh script to launch the game looks like this
                                    #!/bin/bash
                                    "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 _PORT_ "trailblazer" ""
                                    Os: RetroPie 4.5
                                      edmaul69 @Brigane
                                      @brigane he has valiant working. He was asking about trailblazer. I havent tried installing it yet so i cant help him there.
                                      BriganeB R 2 Replies Last reply Reply Quote 1
                                      • BriganeB
                                        Brigane @edmaul69
                                        @edmaul69
                                        Oh my bad. I'll change my post when I get home from work.
                                        Os: RetroPie 4.5
                                          @brigane yeah trailblazer i cannot get it to work...
                                          And i heard good things about it..
                                          Also to show fps press the ~ on keyboard to open console and typ vid_showfps true ..
                                          this will then show you the fps top right side of your screen
                                          Oh if vid_showfps true doesnt work try vid_fps true.
                                          Because i forgot which one it was
                                          BriganeB 1 Reply Last reply Reply Quote 1
                                          • BriganeB
                                            @RetroFreak89
                                            I've updated my post above with the correct info regarding trailblazer. About the fps I can tell you that I run around 28-35 fps through the game with less explosive guns like the handgun, shotgun and machine gun.
                                            After picking up the rocket launcher I got some frame drops sadly. Overall I still think this is more than playable.
                                            Keep in mind though that I'm running RPi 2 so RPi 3 might run this better.
                                            Os: RetroPie 4.5
