    Possible retropie problems
    help
    3 Posts 2 Posters 601 Views
    • Y
      YdoolbRedrum
      I just installed retropie. I installed kodi from the menu so it shows up under ports. It runs fine but for some reason every 5 or 10 seconds the menu pops up on my tv saying 1080p like I have changed resolutions when I haven't. It didn't do it before when I just had kodi and it doesn't do it in retropie. It is very annoying, not sure if it is a setting in retropie since I am running it through retropie or if it's something in kodi. Can anyone help me out.
      • mattrixkM
        mattrixk @YdoolbRedrum
        @ydoolbredrum I'm sorry, I don't know the answer to your question, but I can offer an alternative. I've been successfully running a Dual-boot setup for a year or so. I recently tried using Kodi through RetroPie, but it was a bit too slow overall for my tastes, so I've gone back to the dual-boot setup. I'm using one of the setups from MultiBootPi. The person that makes them sets up little scripts so you can just switch between the 2 (or 3 or 4) systems (Kodi, RetroPi, Pixel, Raspbian, etc).
        Y 1 Reply Last reply Reply Quote 0
        • Y
          YdoolbRedrum @mattrixk
          @mattrixk I'll give it a shot, thanks
