    Kodi (Port) won't save any changes made to the default settings.
    kodisettings
    29 Posts 5 Posters 7.6k Views
      renegade2k
      Hi.
      I'm using RetroPi for a pretty long time and it does not really bother me too much, as i was using it for gaming, but still i wanted to fix it finally:
      Kodi (installed as a Port) won't save any settings and starts "fully resetted" every time!
      Means, doing settings on localisation, UI, CEC(, which makes trouble every time with my AV-Receiver and TV,) or anything else is mostly not saved for the next boot. Some settings are even reset to defaults right after going for the "OK" button. This happens f.e. with the CEC module.
      Sadly i cannot find any information about this in the Wiki, FAQ or the forums.
      Maybe someone already fixed it and can help me with this problem.
      RascasR S 2 Replies Last reply Reply Quote 0
      • RascasR
        Rascas @renegade2k
        @renegade2k This is something I never heard off. Can you please post your Kodi log ? Here is how to do it, and make sure you are not using addons which are considered "illegal" or provide copyrighted content:
        http://kodi.wiki/view/Log_file
        And also, can you copy files to the SD card and open them ? If not, this may indicate that your SD card is faulty.
          Sander2506
          Same probleem here.
          • RascasR
            Rascas
            You both have to provide more info about your setup, the info requested on the "read this first" and the Kodi log, otherwise we can't help.
            • maxbeanzM
              maxbeanz
              This bug was apparently fixed in Kodi 17.4.
              Save skin settings immediately after they have changed instead of only on shutdown
              If you selected anything but 'Exit' in the shutdown menu then the theme settings keep resetting.
              RascasR 1 Reply Last reply Reply Quote 0
                Sander2506
                So if you want to shutdown the pi iT must go true Retropie?
                maxbeanzM 1 Reply Last reply Reply Quote 0
                • maxbeanzM
                  maxbeanz @Sander2506
                  @sander2506 Yes, if you choose 'Exit' back to emulationstation then the settings are kept. Hopefully they can update it to 17.4.
                  • RascasR
                    Rascas @maxbeanz
                    @maxbeanz said in Kodi (Port) won't save any changes made to the default settings.:
                    @maxbeanz Not sure if that is their problem, but I can confirm that if you do "Shutdown" or "Exit" on Kodi, settings will be saved. That is for sure. Well, at least if there isn't any problem with their setup, that's why I asked for more information.
                    • maxbeanzM
                      maxbeanz @Rascas
                      @rascas It doesn't happen everytime, but the settings resetting has happened ever since Kodi changed to v17. I set up my visible categories like Movies, TV Shows, Videos then after choosing 'Shutdown' a few times Kodi starts up with all the Categories back as default. Not sure if it's the exact same problem as above but it's a similar problem.
                      There are a few threads documenting this, for example -
                      https://www.reddit.com/r/kodi/comments/5t519t/skin_settings_not_saving/
                      https://forum.kodi.tv/showthread.php?tid=268143
                      • RascasR
                        Rascas
                        More information will be needed to debug your problem. I have many RPis running RetroPie and Kodi and never saw something like that on mine. I saw people with similar problems, but it was because they were using faulty or problematic SD Cards, which was fixed by using another ones.
                        • maxbeanzM
                          maxbeanz @Rascas
                          @rascas Could you update the script for v17.4 so we can see if it's been fixed ? As I say, if you choose 'Exit' back to emulationstation and then 'Shutdown' from there then everything is fine.
                          • RascasR
                            Rascas
                            Kodi 17.4 is already available on Raspbian Stretch. We don't have plans to update it on Raspbian Jessie. You will have to wait until RetroPie supports Stretch.
                              BuZz administrators @Rascas
                              @rascas that's a shame - a bit premature to drop Jessie updates imho. RetroPie is not switching to stretch anytime soon (there are lots of things to sort for stretch). I may have to consider managing our own port in that case.
                                renegade2k
                                Wow, pretty much replies at once :D
                                Thx for help to everyone, who's trying ^^
                                Let's do it one by one ...
                                @Rascas i'll post the log, asap and if it's still neccessary after all the initial hints posted there.
                                @maxbeanz the setting were resetted, even i was shutting down in kodi. And it was not only about skin settings. Also Add-Ons and such were reset to defaults, but add-ons keep being installed.
                                "I set up my visible categories like Movies, TV Shows, Videos then after choosing 'Shutdown' a few times Kodi starts up with all the Categories back as default. Not sure if it's the exact same problem as above but it's a similar problem."
                                This is exactly, what happens to me. As only it starts every time with the default settings.
                                It's sad the know bug will not be fixed on jessie, as (like @BuZz said) the stretch upgrade will not come that soon.
                                I will try the "first exit, then shutdown" thing.
                                Is there a way to switch RetroPie to kinda "beta" version with stretch support, so it will get kodi 17.4 already now?
                                  BuZz administrators @renegade2k
                                  @renegade2k no. Stretch is not supported yet. We will start adding support after 4.3. even then it will be considered beta until well tested before we switch officially.
                                  • RascasR
                                    Rascas
                                    @buzz The thing is, the changes between Kodi 17.3 and 17.4 are really small, specially on the RPi. The only change that I see that can be related to this is this one:
                                    https://github.com/xbmc/xbmc/commit/49ec2e107fa702d8de691bd55b0b0cb516eea88f
                                    But again, I really doubt that's is their problem, because it only triggers a skin settings save right after you change it, it will always save if you do "Exit" or "Shutdown" in Kodi, even without it this commit.
                                    Continuing to build and support Kodi on Jessie, means 2 more builds (ARMv6 and ARMVv7) + testing it on different systems. We are basically 2 guys doing this on our free time and it requires even more time for us. I would rather spend time helping you porting RetroPie to Stretch than spending more time on this.
                                      @rascas I understand but I have many more packages to maintain. I won't release stretch support until I am sure it's ready and stable, and I want to get 4.3 out first. There may be even more Kodi updates before RetroPie is fully stable on stretch - so if you drop support I have no choice but to look into maintaining Kodi ourselves.
                                      • RascasR
                                        Rascas @BuZz
                                        @buzz I am not dropping support on RetroPie, we still develop and support another OS for the RPi which is still based on Raspbian Jessie also and also includes RetroPie. The thing is, I don't really see an urgency to update it on Jessie. If you all can prove me that their problems are fixed on 17.4, I will update it. Nobody even posted the always required information and their Kodi logs, nobody can support anything like that...
                                          @rascas I can only say that I too have seen the skin settings problem on one of my systems in the past. Seems to be ok now - I probably rebooted rather than exiting at the time - also if Kodi crashes on exit (which it has done in the past), I guess this could cause it to not save too. should rebooting from Kodi save them ?
                                          Please can I have a link to your package sources, as I may as well use them as a base if I am going to include Kodi in RetroPie
                                          [edit] actually they may be available from apt-get source - I'll check.
                                          [edit] they don't seem to be actually, so if you can provide them that would be useful thanks.
                                          • RascasR
                                            Rascas @BuZz
                                            @buzz Kodi can crash on "Exit" only if you are using "kodi-standalone", this was discussed here more than once. Your script on RetroPie-Setup uses "kodi" and crash on exit won't happen. But I have seen here some tutorials, and also on RetroPie github, a part recommending it to use "kodi-standalone" instead. I change it, but some clever guy changed it back...
                                            The Kodi main packages sources aren't available, because the internal cmake system doesn't have an option to create them, this was also already commented upstream, nobody cared...
                                            The original Kodi source is well know, and ours is here:
                                            https://github.com/PIPplware/xbmc
