    Help editing n64 InputAutoCfg file for GPIO
    cpioarcade
    19 Posts 2 Posters 4.0k Views
      kiphouse @simonster
      @simonster said in Any way to access the rest of a 32gb sd card when I flash a 16gb image?:
      @kiphouse
      The should either have been an empty file or just the one line in it. I'm hoping that the stuff at the bottom are the shortcut keys, they aren't in the file, they are like a help screen. If there was nothing in the file, then just type in:
      options mk_arcade_joystick_rpi map=1,2
      press CTRL+X, Y, Enter to save the file and exit the nano editor.
      Then sudo reboot to force your Pi to restart, this should then load the config.
      You need to configure both inputs in Emulation Station, as they are listed as separate devices (GPIOController1 and GPIOController2) and the config doesn't automatically switch from player 1 to player 2 (this is different to a USB gamepad, where if you have 2 identical ones, the config automatically is used on both). Press Start on the first controller and Configure Input, then press a button on controller 2 to set it up.
      Hey. Do u know how I can get the dpad working for my cpio joystick. When I map the joystick it acts as the analog stick in the emu. When I map it as the analog it becomes all wonky.
        kiphouse
        bump
        • simonsterS
          simonster
          The default N64 emulator is not a LibRetro emulator (which differs from most of the emulators in RetroPie), its controls are setup using an entirely different method. You will have to take a look at the documentation: https://retropie.org.uk/docs/Nintendo-64/
          K 2 Replies Last reply Reply Quote 0
            kiphouse @simonster
            @simonster said in How can I get n64 dpad working with cpio joystick?:
            i just ran jstest to see what exactly comes up when i try and use my joystick. up is -32767
            down is 32767 left is -32767 and right is 32767
            when i find my controller in sudo nano /opt/retropie/configs.n64/InputAutoCfg.ini i see this (nothing for dpad, which is all im looking for)
            GPIO Controller 1_START
            [GPIO Controller 1]
            plugged = True
            plugin = 2
            mouse = false
            AnalogDeadzone = 4096,4096
            AnalogPeak = 32768, 32768
            Mempak switch =
            Rumblepak switch =
            Start = button(11)
            C Button D = button(3)
            A Button = button(0)
            R Trig = button(7)
            C Button U = button(3)
            B Button = button(1)
            X Axis = axis(0-, 0+)
            Y Axis = axis(1-, 1+)
            Z Trig = button(6)
            ; GPIO Controller 1_END
              kiphouse
              bump
                kiphouse @simonster
                @simonster said in Help editing n64 InputAutoCfg file for CPIO:
                i installed that parallel emu and my joystick works fine on it, but of course it runs way too slow. help?
                  kiphouse
                  bump
                  simonsterS 1 Reply Last reply Reply Quote 0
                  • simonsterS
                    simonster @kiphouse
                    @kiphouse
                    I am in the middle of moving house, so haven't got my cab available to test but the fields you need are
                    Dpad D= axis(0+)
                    Dpad U= axis(0-)
                    Dpad R= axis(1+)
                    Dpad L= axis (1-)
                    Or maybe 0/1 should be swapped.
                      kiphouse @simonster
                      @simonster i want to tell you how much i appreciate you helping me. After more twelve hour days than id like to admit trying to get it to work i finally did it!! I followed what u last told me to do and put in "0" instead of "2" to make it manual. The last little piece im wondering about is can i map one button as either direction of the analog stick? Im doing this for the wrestling games that all require a tap of the analog to perform your finishing move.
                      • simonsterS
                        simonster @kiphouse
                        @kiphouse checking the Mupen64 documentation: http://mupen64plus.org/wiki/index.php?title=Mupen64Plus_Plugin_Parameters I think you should be able to do this, try:
                        X Axis= button(0,1)
                        Y Axis= button(2,3)
                        You will need to get your button numbers. In the settings above, button 0 is left, 1 right, 2 up and 3 down.
