lr-pcsx-rearmed doesn't start roms after updating
Hi.
Just installed Retropie 4.2 and played a few PSX Games on it, which worked just fine.
Then I updated everything with the RetropieSetup-Script (to 4.2.20 I think; the newest version).
But after this update the psx games don't start anymore. They're loading but then the system throws me back into emulationstation.I tried to delete the lr-pcsx-rearmed and installed it from source but that didn't help.
This is what the runcommand.log says:
Parameters:
Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Grand Theft Auto.cue" --appendconfig /dev/shm/retroarch.cfg
Starting PCSX-ReARMed
Running PCSX Version 1.9 (Sep 12 2017).
psxMap: warning: wanted to map @80000000, got 0x74202000
Init new dynarec
testing if we can run recompiled code..
test passed.
warning: RAM is not directly mapped, performance will suffer
Mapped (RAM/scrp/ROM/LUTs/TC):
77000000/1f800000/1fc00000/08000000/74dc5000
found BIOS file: scph5000.BIN
RGB565 supported, using it
plugin: plugins/builtin_gpu
plugin: plugins/builtin_spu
plugin: plugins/builtin_pad
Plugins loaded.
Loaded CD Image: /home/pi/RetroPie/roms/psx/Grand Theft Auto.cue[+cue].
Track 01 (DATA) - Start 00:02:00, Length 05:52:04
Track 02 (AUDIO) - Start 05:56:04, Length 02:16:60
Track 03 (AUDIO) - Start 08:13:64, Length 07:24:46
Track 04 (AUDIO) - Start 15:39:35, Length 09:40:61
Track 05 (AUDIO) - Start 25:21:21, Length 09:36:06
Track 06 (AUDIO) - Start 34:58:27, Length 07:30:16
Track 07 (AUDIO) - Start 42:29:43, Length 10:58:11
Track 08 (AUDIO) - Start 53:28:54, Length 03:10:61
Track 09 (AUDIO) - Start 56:40:40, Length 01:11:58
Track 10 (AUDIO) - Start 57:53:23, Length 01:00:38
Track 11 (AUDIO) - Start 58:54:61, Length 08:44:21
selected sound output driver: libretro
CD-ROM Label: GTA
CD-ROM ID: SLUS00106
CD-ROM EXE Name: SLUS_001.06;1
ari64_reset
Compile at bogus memory address: 00200000Looks fine in my opinion. :-/
I'd appreciate your help. I'm pretty desperated. Thank you!
@juicebag85 try putting your psx bios' in your roms folder and see if it works. If it does work that way, i can tell you how to fix it to work the correct way.
I am also having the same issue here is the output I am getting:
/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg /home/pi/RetroPie/roms/psx/"LEGO Racers.cue"
Running PCSX Version 1.9 (Sep 17 2017).
psxMap: warning: wanted to map @80000000, got 0x74223000
Init new dynarec
test passed.
77000000/1f800000/1fc00000/08000000/74de6000
found BIOS file: SCPH-70004_BIOS_V12_PAL_200.ROM1
Plugins loaded.
Loaded CD Image: /home/pi/RetroPie/roms/psx/LEGO Racers.cue[+cue].
Track 01 (DATA) - Start 00:02:00, Length 49:51:57
CD-ROM Label: LEGORACERS
CD-ROM ID: SLUS00581
CD-ROM EXE Name: SLUS_005.81;1
ari64_reset
Disabled speculative precompilation
Compile at bogus memory address: 80200000I have tried removing/installing/updating, re downloading BIOs and putting them in the psx/bios folders.
I am using RetroPie 4.2.21, if I can't get it to work I will have to revert to an old backup image (ALWAYS MAKE BACKUPS FOLKS!)
I just updated to 4.3 and the same thing happens, i'll try deleting config files tomorrow and see if that is what is causing it
@madmodder123
I was able to fix it by deleting all but one BIOS file (SCPH1001.BIN)
