    Help with first power up
    retropie 4.2raspberrypi 3startuperror -8
    9 Posts 3 Posters 2.9k Views
    • E
      EliteAnorak
      Pi Model: 3
      Power Supply: 2.5A Power Supply
      RetroPie Version: 4.2
      Built From:Pre Made SD Image on Retro Pie Website
      USB Devices Connected: none yet
      Controllers Uses: None yet
      Error Message received: "end Kernel panic - not syncing: Requested init /usr/lib/raspi-config/init_resize.sh failed (error -8)"
      Guide Used: https://retropie.org.uk/docs/First-Installation/
      All Ive done so far is install the image on an sd card (using Win32DiskImager) that I formatted (using SD Card Formatter). Whenever I start it up, I get that error code almost immediately. I thought I mightve gotten a bad SD card, so I got another one but resulted in the same error. Any ideas?
      akafoxA 1 Reply Last reply Reply Quote 0
      • HurricaneFanH
        HurricaneFan
        Looking at the expand file system stuff, looks like you can manually try to kick it off again.
        https://www.raspberrypi.org/documentation/configuration/raspi-config.md
        • E
          EliteAnorak
          I cant even do anything with the pi, let alone manually starting it again. I plug in the power, and I get a black screen with lines of code ending with that error.
          HurricaneFanH 1 Reply Last reply Reply Quote 0
          • HurricaneFanH
            HurricaneFan @EliteAnorak
            @eliteanorak Was your 4.2 image unzipped before you wrote it to the 2 SD cards?
            • akafoxA
              akafox @EliteAnorak
              @eliteanorak If all else fails..try Etcher instead to write your image. There is a chance your image might be corrupted during download as well.
              As HurricaneFan said make sure to uncompress it. Make sure your card is formated fat32...the rewrite the image.
              • E
                EliteAnorak @HurricaneFan
                @hurricanefan I did unzip it, but I didnt really trust that program. Im installing 7zip now.
                • E
                  EliteAnorak @akafox
                  @akafox I just finished reformatting my sd card to FAT32, and Im going to use Etcher to write the image. After I use 7zip to unzip the file.
                  HurricaneFanH 1 Reply Last reply Reply Quote 1
                  • akafoxA
                    akafox @EliteAnorak
                    @eliteanorak I was going to ask about that...yeah..7zip is MUCH better.
                    • HurricaneFanH
                      @eliteanorak Good luck!
