    Software Shutdown using Atxraspi
    atxraspishutdown
    28 Posts 3 Posters 6.9k Views
      crazydude2 @cyperghost
      @cyperghost Hi I think it is now working well. Thanks for all your help. What do you mean by posting outfindings? Just so people know
      nano /opt/retropie/supplementary/emulationstation/emulationstation.sh had to be changed to sudo nano /opt/retropie/supplementary/emulationstation/emulationstation.sh to allow editing
      and the script also had to be altered to
      #!/bin/sh
      esdir="$(dirname $0)"
      while true; do
          rm -f /tmp/es-restart /tmp/es-sysrestart /tmp/es-shutdown
          "$esdir/emulationstation" "$@"
          ret=$?
          [ -f /tmp/es-restart ] && continue
          if [ -f /tmp/es-sysrestart ]; then
              rm -f /tmp/es-sysrestart
              sudo /usr/local/bin/softshutdown.sh 1
              sudo reboot
              break
          fi
          if [ -f /tmp/es-shutdown ]; then
              rm -f /tmp/es-shutdown
              sudo /usr/local/bin/softshutdown.sh 4
              sudo poweroff
              break
          fi
          break
      done
        cyperghost @crazydude2
        @crazydude2 Outfindings? ... tell me if it works ;)
        make 3 backticks liker here ```
        in beginning and ending of codeblock
        One backtick ` in beginning and ending of line or word makes it red
        __ makes bold
        ~~ makes striceout
        _ makes italic
        I'm wondering that you need root-access for editing this file!
        can you post me output of ls -l /opt/retropie/supplementary/emulationstation please
          @cyperghost
          pi@retropie:~ $ ls -l /opt/retropie/supplementary/emulationstation
          total 4756
          -rw-r--r-- 1 root root 451 Jul 11 15:38 CREDITS.md
          -rwxr-xr-x 1 root root 4804496 Jul 11 15:38 emulationstation
          -rwxr-xr-x 1 root root 526 Sep 19 20:56 emulationstation.sh
          -rwxr-xr-x 1 root root 527 Sep 19 20:56 emulationstation.sh.save
          -rw-r--r-- 1 root root 5667 Jul 11 15:38 GAMELISTS.md
          -rw-r--r-- 1 root root 10181 Jul 11 15:38 README.md
          drwxr-xr-x 3 root root 4096 Jul 21 23:18 scripts
          -rw-r--r-- 1 root root 27979 Jul 11 15:38 THEMES.md
            @crazydude2 Okay correct... yes we need sudo for editing - forget that! thx
            Now you can test shutdown via ES MainMenu... it should work like you press the button.
            Have fun
              @cyperghost Yes i can confirm it now works as it should. I have tried all combinations i can think of all with success. Thanks for all the help.
                @crazydude2 Okay, keep in mind that if you update RetroPie it may happen you will loose settings to /opt/retropie/supplementary/emulationstation/emulationstation.sh as the two lines I added will be erased. So you have to add them manually....
                This will only affect the software-shutdown. Does the LED also blink if you choose software shutdown? I'm just interested to know ;) It should so as it triggers the same GPIO as the button press ;)
                  @cyperghost Yes the led does still flash on software shutdown
                    cyperghost
                    @crazydude2 Wow awesome! So have fun...
