    Wireless Battery Indicator (PS3)
    batterywirelessps3
    22 Posts 11 Posters 10.0k Views
      silverbullet @madmodder123
      @madmodder123 I tried looking for that, but I don't see that sixad is logging on my system anymore. It looks like the logrotate is setup to rotate the logs in that /var/log/sixad file, but that file doesn't exist. I looked through the documentation and I don't see any mention of logging. I am not sure if the logging was removed and the remnants of the log rotation weren't removed? If you have any suggestions of where the logs are now stored, I would appreciate it.
      Thanks!
      madmodder123M 1 Reply Last reply Reply Quote 0
      • madmodder123M
        madmodder123 @silverbullet
        @silverbullet
        So I did a little detective work.
        It looks like in RetroPie 4.4/Stretch the /var/log/sixad file was removed and the logs for sixad are sent to journald ("/run/log/journal/44377289e4ad47738189eab7cbdb463a/system.journal" on my Pi) and i'm not sure if the script can read from that file as it contains a bunch of different logs.
        to test this you can try changing batCheck.py from
        "logPath='/var/log/sixad'" to "logPath='/run/log/journal/44377289e4ad47738189eab7cbdb463a/system.journal'" (note the big string of characters in the file path is probably different on your Pi!) and then running the script
