    Advance Mess and BBC Micro and joystick control
    advance messjoystickbbc micro
    75 Posts 5 Posters 11.2k Views
      teller
      splendid!
      here's my joystick config for SEE EMILY PLAY ;)
      bbcbp128[home_pi_retropie_roms_bbcmicro_seeemilyplay]/input_map[key_capslock] joystick_digital[046d_c219,0,0,1] or keyboard[0566_3029,capslock]
      bbcbp128[home_pi_retropie_roms_bbcmicro_seeemilyplay]/input_map[key_ctrl] joystick_digital[046d_c219,0,0,0] or keyboard[0566_3029,lcontrol]
      bbcbp128[home_pi_retropie_roms_bbcmicro_seeemilyplay]/input_map[key_space] joystick_button[046d_c219,tr] or keyboard[0566_3029,space]
      bbcbp128[home_pi_retropie_roms_bbcmicro_seeemilyplay]/input_map[key_n] joystick_button[046d_c219,tl] or keyboard[0566_3029,n]
      bbcbp128[home_pi_retropie_roms_bbcmicro_seeemilyplay]/input_map[key_enter] joystick_button[046d_c219,a] or keyboard[0566_3029,enter]
      I use a Logitech F710 which is working very well on RetroPie!
      The funny thing was that the capslock didn't turn up to be saved, so I had to manually enter that line into advmess.rc.
        teller
        Are there any games that only work with the bbcb, that can't be loaded on bbcbp128?
        I ask because I think it's not possible to switch between the two without modifying manually the emulators.cfg.
          SpudsMcToole Banned @teller
          @teller said in Advance Mess and BBC Micro and joystick control:
          I found a few, I'd recommend using bbcb rather tham bbcbp128.
            teller
            unfortunately in this game SABRE WULF the input key SHIFT is used for using the sword. It can't be mapped twice, otherwise i get a Type mismatch error and the autoboot command looks like this:
            CHAIN 2LOAD2 instead of CHAIN "LOAD"
            input map (SWORD):
            bbcb[home_pi_retropie_roms_bbcmicro_sabrewulf]/input_map[key_shift] joystick_button[046d_c219,a] or keyboard[0566_3029,lshift]
            autoboot command
            bbcb[home_pi_retropie_roms_bbcmicro_sabrewulf]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(200); simulate_key(key_lshift,150); simulate_key(key_2,50); delay(200); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_lshift,150); simulate_key(key_2,50); delay(200); simulate_key(key_enter,75); delay(75);
            I also tried rshift.
            In other words, a game which uses the same keys for the autoboot command can't be used.
              spud11 @teller
              @teller Could you use capslock instead? That's what I use in the script_play commands.
                teller @spud11
                @spud11 Good idea!
                But if I try key_capslock I get
                CHAIN load
                  spud11 @teller
                  @teller Ok. Repeat the capslock command in your script_play so that it is capitalised again and make sure you use the "2" to create the quotations. Have a look at some of my scripts in the other thread.
                    spud11 @teller
                    @teller In fact, here are my scripts for you:
                    bbcb/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_chuckie]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(200); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_c,75); delay(75); simulate_key(key_k,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_g,75); delay(75); simulate_key(key_g,75); delay(75); simulate_key(key_2,50); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_thrust]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_elite]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_capslock,75); delay(75); simulate_key(key_quote,75); delay(75); simulate_key(key_1,75); delay(75); simulate_key(key_b,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_chuckie]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(200); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_c,75); delay(75); simulate_key(key_k,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_g,75); delay(75); simulate_key(key_g,75); delay(75); simulate_key(key_2,50); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_elite]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_capslock,75); delay(75); simulate_key(key_quote,75); delay(75); simulate_key(key_1,75); delay(75); simulate_key(key_b,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_thrust]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_repton]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_repton]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_tempest]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_m,75); delay(75); simulate_key(key_p,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_tempest]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_m,75); delay(75); simulate_key(key_p,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_meteors]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_m,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_meteors]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_m,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_t,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_snapper]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_p,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_snapper]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_c,75); delay(75); simulate_key(key_h,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_i,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_space,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_s,75); delay(75); simulate_key(key_n,75); delay(75); simulate_key(key_a,75); delay(75); simulate_key(key_p,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcb[home_pi_retropie_roms_bbcmicro_loderunner]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_capslock,75); delay(75); simulate_key(key_quote,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_n,75); delay(100); simulate_key(key_space,100); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                    bbcbp128[home_pi_retropie_roms_bbcmicro_loderunner]/script_play delay(750); simulate_key(key_scrlock,75); simulate_key(key_capslock,75); delay(75); simulate_key(key_quote,75); delay(75); simulate_key(key_r,75); delay(75); simulate_key(key_u,75); delay(75); simulate_key(key_n,75); delay(100); simulate_key(key_space,100); simulate_key(key_2,75); delay(75); simulate_key(key_l,75); delay(75); simulate_key(key_o,75); delay(75); simulate_key(key_d,75); delay(75); simulate_key(key_e,75); delay(75); simulate_key(key_2,75); delay(75); simulate_key(key_capslock,75); delay(75); simulate_key(key_enter,75); delay(75);
                      teller
                      That trick with double capslock didn't work either.
                      Thanks for your scripts.
                      I also tested your default script_play commands on my system.
                      All I get is
                      CHAIN 2load2
                      do you have different keyboard settings? I didn't change anything in raspi-config.
                        spud11 @teller
                        @teller I think you may have capslock on automatically. That can be the only explanation if using one of my scripts switches you to small letters when you "press" capslock.
                        Leave the capslock out and just use the "2" key to create the quotations (capslock + 2 should create quotations).
                        It's probably the difference between the UK-style keyboard and the US-style keyboard. The BBC Micro was a UK computer. I'm using a US-style keyboard. On my US-style keyboard, the quotation key appears next to the enter key. However, in order to create quotations using the capslock on the BBC Micro, I need to press the "2" key. I figured this out by trial and error by just typing various keys.
                          teller
                          Yeah, must be a keyboard setup difference.
                          Or it could be that we use a different Acorn DFS Basic ROM?
                          But if I have another game that uses capslock, then the autoboot won't work as well.
                          THRUST uses capslock if I remember.
                            spud11 @teller
                            @teller Possibly. Advmess is a mess indeed.
                            You could have separate scripts for Sabre Wulf and for Thrust - one that uses capslock and one that doesn't.
                            Worst case, remove all the scripts, start a BBC Micro game, attach your keyboard to the Pi (or use a bluetooth keyboard) and experiment by pressing keys with or without capslock/shift to see what comes up on the BBC. That's what I ended up doing for a few of my scripts, particularly because I found the * was in a completely different location on the BBC from where it was on my keyboard.
                            T 1 Reply Last reply Reply Quote 1
                              teller @spud11
                              @spud11 found the right key to get " working ! i need to press alt + 2, then I'll get "
                                teller
                                Shift for Thrust doesn't work on my joystick although it's mapped correctly.
                                bbcb[home_pi_retropie_roms_bbcmicro_thrust]/input_map[key_shift] joystick_button[046d_c219,a]
                                the autoboot script has no shift command in use.
                                i don't know why, advmess is driving me crazy!
                                  spud11 @teller
                                  @teller In my advmess.rc file, I have:
                                  input_map[key_lshift] keyboard[0,lshift] or joystick_button[0079_0006_3,2]
                                  input_map[key_rshift] keyboard[0,rshift]
                                  input_map[key_shift] auto
                                  bbcbp128[home_pi_retropie_roms_bbcmicro_thrust]/input_map[key_lshift] joystick_button[0079_0006_3,2] or keyboard[0,lshift]
                                  bbcbp128[home_pi_retropie_roms_bbcmicro_thrust]/input_map[key_rshift] joystick_button[0079_0006_3,2] or keyboard[0,lshift]
                                  Obviously, the joystick buttons will be different for you. There's unfortunately not a lot of consistency overall between everyone's setups, so experimentation is probably the only way to get there.
