    newbie building retropi project
    newbie question
    1 Posts 1 Posters 425 Views
      gcairns84
      Hi I am really new to all this and going to put together a really simple retropi setup using:
      Pi model 3
      smartpi case and 7" screen
      power supply that comes with smartpi
      will use the latest version of retropi
      hopefully ps3/ps4 controller(whichever is better)
      The only thing i am wondering is the best way to get sound for it and was wondering if the retropi supports the speaker pHat that's about the size of the pi zero or is there a better and easier way to set up sound for it that still makes it semi potable
