    Need help configuring xboxdrv with xboxdrv + sorr + sixaxis
    xboxdrvsixaxissorr
    1 Posts 1 Posters 644 Views
    • N
      nimp
      Hello,
      I'm drowning in documentation, and after hours of testing I can't do what I want.
      Anybody who tried it will understand : I want to play Streets of Rage Remake with the DPAD, but by default the game detects the analog stick as the first axis, and the game doesn't allow me to redefine it.
      I do realise that xboxdrv is a great tool, and I did found how to map square, triangle, cross, round... but I can't find a way to do that simple thing.
      Tried joy2key with no luck, there may be something around gamecontrollerdb but I don't know...
      Well, it seems that the former non-trivial way to use a sixaxis with a computer did much harm and that xbox360 controllers is THE controller to use with a computer, and sadly it looks like just EVERYBODY uses it.
      At this point I have :
      #!/bin/sh
      #--silent
      #--force-feedback
      #--evdev-absmap ABS_X-=,ABS_X+=DPAD_X+,ABS_Y-=DPAD_Y-,ABS_Y+=DPAD_Y+
      #--trigger-as-button
      #>/dev/null \
      #--evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_BASE3=lt,BTN_BASE4=rt,BTN_TRIGGER=back,BTN_TOP=start,BTN_SOUTH=guide,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl
      #--dpad-only
      #--dpad-as-button \
      sudo /usr/local/bin/xboxdrv --evdev /dev/input/event3
      --detach-kernel-driver
      --mimic-xpad
      --axismap Y1=DPAD_Y,X1=DPAD_X
      --evdev-keymap KEY_#301=a,KEY_#302=b,KEY_#300=x,KEY_#303=y,KEY_#290=tr,KEY_#289=tl,KEY_#291=start,KEY_#288=back,KEY_#704=guide,KEY_#299=rb,KEY_#297=rt,KEY_#298=lb,KEY_#296=lt
      This last one doesn't work, but at this point I'm not really what to try
