    RetroPie v4.3 not runing, and screen display problem.
    v4.3 not runingscreen display
    3 Posts 3 Posters 752 Views
      Rl
      Hi all
      A.
      I install .img file of RetroPie v4.3 on SD card
      But on my raspberry pi3 is not work..
      have a photo
      you can help me please?
      B.
      my raspberry pi3 not give display immediately only on the little screen that connect to the board.
      but if I want display on another screen with only HDMI contact
      I need to contact the small screen do power on the raspberry pi3
      and after change the connectors..
      you have idea about that?
      Tanks!
        @rl Looks like a faulty SD card - or image flash gone wrong. Have you tried re-flashing the image again ?
        For the 2nd part - you'll find plenty of resourced about connecting another display to the PI - what type of small display are we talking about ?
        danielmewhouseD 1 Reply Last reply Reply Quote 0
        • danielmewhouseD
          danielmewhouse @mitu
          @mitu I've the same idea. I've got the same issue once burning sdcards with DD and win32disk imager. Etcher solved my problems.
          It's no use!!! Take this!!!
