    save state issue, need help
    save states
    3 Posts 2 Posters 906 Views
      shawmr91
      I recently started putting together a retropie, current running the newest 4.3 on a raspberry pi 3. I've uninstalled and reinstalled multiple times but i still have this same issue so if someone could help me out id really appreciate it because I have researched for weeks and cant find a solution.
      so whats happening is when i go into a game (any game in any emulator) everything works fine except whenever i hit a direction left or right + a button it activates the save state selection option. this is a problem because if youre in the middle of a jump in a direction it interrupts the input to switch the save state slot. for example left+a button will go down numerically in save state slots and right+a button will go up numerically in save state slots and every time those button combinations are pressed it interrupts the games normal input.
      • lostlessL
        lostless @shawmr91
        @shawmr91 looks like you set the hotkey as A. This is bad. I assume you press A and start to exit? You are activating the save state changing by pressing A and left or right. Try setting the hotkey as select or some other other button that is used very little. On my Ps3/xbox controllers i use the home buttons and on my Ps1 controllers I use L3.
          shawmr91
          shows how much of a noob i am haha. you are right i accidentally set the hot key to a. thanks alot.
