System not showing up even though games installed?
In my case I have installed PSP Mini games, and yet the system doesn't show up on my active list even though I have the emulator running.
So they are installed, but I cannot access them right now.
Any help would be great.
@digi What emulators have you installed and what format are the games ? Where did you copy them ?
All files I've downloaded from
[removed]
Everything seems to work just fine for most systems, but this one and Virtual Boy have the items installed in the correct areas and don't register to the Retropie.
As for the emulators I only go with the ones that come packaged on Retropie.
@digi you cannot name rom site here. It is against the forum rules. Second you didnt answer any of his questions.
@digi What extension have the ROM files ?
Check in the https://retropie.org.uk/docs/PSP/ page for the file extensions recognized by the emulators and the correct folders. If in doubt, make sure the file names are in lowercase. Restart ES and see if the games appear under the PSP folder.
You said that your have the emulator running, but eash system/folder uses its own emulator, so you might have a ROM under the Nes folder working, but that's using a different emulator. -
Huge apologies for breaking the rules.
I'm very new at this so I was answering what I thought was the question, when it wasn't that.
Tonight when I get a change I'll look and be more correct in my answer to what you're looking for.
