    Using a momentary v. toggle power switch
    momentarytogglekeyboardswitchpower
    4 Posts 2 Posters 1.5k Views
      suleske
      Here's a video update of my project status:
      https://atari600xl.blogspot.com/2017/11/video-update-controlblock-switch.html
      Today I realized the power switch must be latching, not momentary. You can see the results in the video.
      What I'm wondering is if:
      1. The code can be recompiled for a momentary switch and if not,
      2. Does anyone have a suggestion for a simple latching circuit that will allow the keyboard RESET key to act as a latching toggle for power?
      I suppose I've a third Q:
      3. If "no" to both 1 and 2, do you have a suggestion for adding a power switch that will blend with this design? Note: I've already installed the Ethernet port where the original power switch was located.
        suleske @suleske
        @suleske I think I answered my own question. If I really want to use the keyboard, then here's an example of how to do #2:
        caver01C S 2 Replies Last reply Reply Quote 0
        • caver01C
          caver01 @suleske
          @suleske Cool circuit. Reminds me of playing with a Miller Solar Engine to make BEAM robots. Entertaining video to boot!
          What was that bit you said toward the end when the cap discharged? "Half a bee's dick"? Hilarious. I have heard "Bob's your uncle" but never that one before.
            suleske @suleske
            @suleske I found several inexpensive and simple circuits I could build. This little board has some added features (e.g. setting the key press switch delay), so I bought it: https://www.ebay.com/itm/262199569276
