    Steven Selph's Scraper Will not download.
    steven selphsscraperhelp
    22 Posts 3 Posters 5.8k Views
    • F
      funimation
      Hey everyone. Does anyone know how to help. After trying to install Steven Selph's Scraper from the optional packages, I get an error message. I am running retro Pie 4.3 on Raspberry pi 3. The message says " Could not successfully install Scraper for Emulation station by Steven Selph (/home/pi/RetroPie-Setup/tmp/build/scraper/scraper not found). When downloading any other optional packages it works fine. Help would be greatly appreciated, wanting to scrape video file previews for my roms
      • retroprogrammerR
        retroprogrammer
        Are you connected to Ethernet or Wi-Fi
        Here is me converting the original Xbox for a case:
        https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
        Check out my GitHub: https://github.com/retro-programmer
        • F
          funimation
          This post is deleted!
          • retroprogrammerR
            retroprogrammer
            maybe try installing Retropie on a new SD card and see what happens
            • F
              funimation @retroprogrammer
              @retroprogrammer I am connected to WiFi. Should I try Ethernet? I was unaware that would make a difference. thanks
              • retroprogrammerR
                retroprogrammer
                @funimation its okay if that doesn't work try a new SD card
                  mitu Global Moderator @retroprogrammer
                  @retroprogrammer Why would you think a new card is needed ?
                  • F
                    @retroprogrammer Hmm.. I have seen some people say just a fresh install will make it work. Just didnt want to wipe things. Guess I will make a backup of roms.
                    • retroprogrammerR
                      retroprogrammer
                      My bad just write over the old one sorry
                      • retroprogrammerR
                        retroprogrammer
                        yes a fresh install will do it sorry @funimation @mitu
                        • retroprogrammerR
                          retroprogrammer
                          Just woke up a little drowsy
                            I remember someone had a similar problem - see if this will fix the error:
                            https://retropie.org.uk/forum/topic/14408/scraper-installation-failed/21?page=2
                            • retroprogrammerR
                              retroprogrammer
                              @funimation does Ethernet make any difference?
                              • F
                                funimation @mitu
                                @mitu thanks for the suggestion . After trying to set it up manually, it stops here.
                                Not quite sure what to type from here on .
                                • F
                                  @retroprogrammer
                                  After plugging it into the ethernet it did not work. However I tried manually and am stuck. See above picture.
                                    mitu Global Moderator @funimation
                                    @funimation The files in /opt/retropie/supplementary/golang seem empty. Delete that folder and then use the setup script to re-install the golang package, then try installing the scraper package.
                                    • F
                                      funimation @mitu
                                      @mitu Interesting. Thank you! I am still learning. This is my second pi. I cannot try this till after work today. I will respond this evening and we will see how it went!
                                      • F
                                        funimation @funimation
                                        @funimation Would I delete these from the config script, or within retropie setup?
                                          @funimation You'd delete them from the command line - either log in via SSH on the device, or exit EmulationStation. Then execute
                                          cd /opt/retropie/supplementary/
                                          sudo rm -fr golang
                                          After the folder is deleted, start Emulationstation (type emulationstation at the command prompt), go to the RetroPie setup script and re-install the golang package, then try again to install and run the Scraper.
                                          • F
                                            funimation @mitu
                                            @mitu it seems to have worked somewhat. I am currently stuck at “getting sources for ‘scraper’ : Scraper for Emulation Station by Steven Selph”
                                            It hasn’t moved for about 20 minutes . Maybe I’ll wait an hour or so and if nothing has happened I’ll retry.
                                            Sorry for all the posts ! Hopefully it is good now. It is connected to Ethernet. Maybe I’ll also try WiFi
