    Volume up/down with USB-sound card
    usb soundhotkey
    4 Posts 3 Posters 1.3k Views
    • O
      oloff3
      Hi!
      I have been building a GameBoy Zero into a Nintendo DS and are almost done.
      But I can't get the hotkeys for volume up and down to work.
      I just have added the lines into my GPIO joypad cfg files to bind input_volume_up = "button value".
      Edit:
      I have managed to get the volume setting to work from the EmulationStation menu but not with Hotkeys while playing a game.
      Any idea what I am doing wrong?
      Best regards
      Oloff3
      • retroprogrammerR
        retroprogrammer
        Did you setup Hotkeys when you were imputing the button controllers for your Game Boy ,Nintendo DS, Nintendo DS Boy :)
        Here is me converting the original Xbox for a case:
        https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
        Check out my GitHub: https://github.com/retro-programmer
        • O
          oloff3 @retroprogrammer
          @retroprogrammer
          I configured one button to hotkey. And hotkeys like exit emulation, reset, state saves works fine, but for some reason the volume control don't work.
            mitu Global Moderator @oloff3
            @oloff3 You could try something like:
            input_volume_up = +<button value>
            input_volume_down = -<button value>
            or another approach is described here https://retropie.org.uk/forum/topic/2377/control-volume-through-retroarch-with-keyboard/4, outside of RetroArch. The example in the topic is more for the keyboard use, but if you can make the events appear as keypresses, the principle is the same.
