    Leaderboards problem w/ retropie
    leaderboardsretroachievemen
    35 Posts 3 Posters 7.5k Views
    • VinzV
      Vinz
      Hi! first of all I want to thank all developer of retropie, I'm using retropie from more than year and what I can say is that is awesome!
      with Retroarch 1.6.8 I saw in the wiki that retroachievements Leaderboards are supported, but even if I added "cheevos_leaderboards_enable = true" in my retroarch.cfg located in /opt/retropie/configs/all/retroarch.cfg it doesn't work.
      I have problem only on leaderboard, in fact Retroachievements work well.
      could you please help me?
      I have already upgraded retropie to the last version 4.3.7
      • retroprogrammerR
        retroprogrammer
        @Vinz Did you follow this tutorial: https://github.com/RetroPie/RetroPie-Setup/wiki/RetroAchievements
        or this one: https://retropie.org.uk/docs/RetroAchievements/
        Here is me converting the original Xbox for a case:
        https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
        Check out my GitHub: https://github.com/retro-programmer
        • retroprogrammerR
          retroprogrammer
          @Vinz and your WIFI and Ethernet are fine?
          • VinzV
            Vinz
            Hi @retroprogrammer, I followed this: https://github.com/RetroPie/RetroPie-Setup/wiki/RetroAchievements and my WIFI works. I don't use Ethernet..
            • retroprogrammerR
              retroprogrammer
              yep, and you setup a account on retro achievements site: http://retroachievements.org/
              • VinzV
                Vinz
                Yes I created an account and added my credential in retroarch.cfg. In fact the retroachievements work...for example I tried different games and retroachievements work but Leaderboards don't.
                • retroprogrammerR
                  retroprogrammer
                  you should add the line cheevos_verbose_enable = true in /opt/retropie/configs/all/retroarch.cfg to see if you successfully logged in and how many achievements you have unlocked
                  • retroprogrammerR
                    retroprogrammer
                    Have you played for long enough to get on a leader board?
                    VinzV 1 Reply Last reply Reply Quote 0
                    • VinzV
                      Vinz
                      Yes, I have already added this line and give me the output I have already logged
                      • VinzV
                        Vinz @retroprogrammer
                        @retroprogrammer Yes for different games (i.e. mario kart 64, space invaders (gb))
                        • retroprogrammerR
                          retroprogrammer
                          did you play games for long after you setup retro achievements
                          • retroprogrammerR
                            retroprogrammer
                            and are the games you play supported my retro achievements
                            • VinzV
                              @retroprogrammer about a total of four hours in three days. For example I made a time of about 1 minute and 53 seconds on the "Leaderboard: Luigi Raceway (Mario Kart 64)" but I don't see my name, whereas all the other retroachievements of this game work
                              • retroprogrammerR
                                retroprogrammer
                                @Vinz Maybe try a Ethernet cable?
                                • VinzV
                                  @retroprogrammer I could try, even if the router is very far from my retropie system
                                  • retroprogrammerR
                                    retroprogrammer
                                    Yes see what happens :)
                                    • VinzV
                                      @retroprogrammer I hope it works, even if it will be a temporary solution because I prefer WIFI :)
                                      thank you so much, I will give you a feedback when I try your solution!
                                      • VinzV
                                        Vinz
                                        @retroprogrammer Tried the ethernet but unfortunately the same result. Only retroachievements work, leaderboards don't
                                        • retroprogrammerR
                                          retroprogrammer
                                          I am not sure any more
                                          • VinzV
                                            @retroprogrammer thanks anyway for your precious and fast support. I hope to solve this problem because it would be so cool use that functionality. do you use retroachievements, and if yes leaderboards work to you?
