    Leaderboards problem w/ retropie
    leaderboardsretroachievemen
    35 Posts 3 Posters 5.6k Views
    • retroprogrammerR
      retroprogrammer
      @Vinz Just check the file /opt/retropie/configs/all/retroarch.cfg again to see if everything is there, then update Retropie through the setup script again and then see what happens?
      Here is me converting the original Xbox for a case:
      https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
      Check out my GitHub: https://github.com/retro-programmer
      • retroprogrammerR
        retroprogrammer
        I
        @vinz said in Leaderboards problem w/ retropie:
        do you use retroachievements, and if yes leaderboards work to you?
        No but I will do it today to see if it works for me and I will report :)
        • retroprogrammerR
          retroprogrammer
          @Vinz I have you used retro achievements in a previous build and it did work
          VinzV 1 Reply Last reply Reply Quote 0
          • VinzV
            Vinz @retroprogrammer
            @retroprogrammer already done upgrade, but all necessary lines are there..BTW it is the first time I use retroachievements, so it is the first build in which I use them..I will wait your feedback, so let me know if leaderboards work to you, thanks
            • retroprogrammerR
              retroprogrammer
              @Vinz it seems like it is not working for me to!
              • VinzV
                @retroprogrammer what a pity..
                • retroprogrammerR
                  retroprogrammer
                  Have you tried asking a administrator, I think retro achievements is down or something
                    mitu Global Moderator @retroprogrammer
                    @retroprogrammer said in Leaderboards problem w/ retropie:
                    It doesn't seem to be down from here, the activity feed is active and constantly updating.
                    • retroprogrammerR
                      retroprogrammer
                      @mitu Then I don't know what the problem is
                      • retroprogrammerR
                        retroprogrammer
                        @mitu Even I tried setting it up and it didn't work?
                          mitu Global Moderator @Vinz
                          @vinz How are you checking that leaderboards work ?
                          • VinzV
                            Vinz @mitu
                            @mitu I made some time trials lap times in mario kart 64 time trial that beated the times of some users, and I reached some highscores in several games.
                              @vinz Do you have 'Hardcore Mode' enabled in RA ? According to the announcement (http://retroachievements.org/viewtopic.php?t=5543)
                              You need to enable both Hardcore Mode and Leaderboards for them to be active.
                              • VinzV
                                Vinz @mitu
                                @mitu No, I activated only leaderboards..I didn't know that necessitated also hardcore mode...I will add the hardcore mode and I will let you know, thanks!
                                • VinzV
                                  Vinz
                                  @mitu Great!! adding the hardcore mode, leaderboards work!!! thanks!
