    "B" turns to "X" on second controller after restart
    controller helpcontroller probcontroller issucontroller setu
    22 Posts 8 Posters 4.8k Views
    • danielmewhouseD
      danielmewhouse @Notechskill
      @notechskill said in "B" turns to "X" on second controller after restart:
      @danielmewhouse just to be clear. On my keyboard hit f4 and go to the command prompt and type in exactly what you have typed out there?
      If your problem is on EmulationStation, use "sudo nano /home/pi/.emulationstation/es_input.cfg" to edit the file. You'll need to find the X and B buttons on the config file and swap the id value.
      It's no use!!! Take this!!!
      chipsnblipC 1 Reply Last reply Reply Quote 0
      • chipsnblipC
        chipsnblip @danielmewhouse
        @danielmewhouse said in "B" turns to "X" on second controller after restart:
        i could be wrong, but sudo shouldn't be necessary when editing files in one's own home directory
