    Retropie v3.6 8bitdo NES30 Pro Issues (After using GitHub and Floobs video)
    6 Posts 1 Posters 1.4k Views
    • Dave BD
      Dave B
      Pi Model: 3
      RetroPie Version Used: (3.6.0)
      USB Devices connected: Xbox One Controller & USB Logitech Mouse and Keyboard combo
      Issue: 8bitdo NES30 Pro connection issue
      I followed Floobs video to the T except I am using the NES30 Pro the device is showing up registered in the Bluetooth configure menu but won't connect after the initial connection was made the first time I tried. Even after the first connection I still could not get it to show in ES but now it will not connect. I tried to reboot and restart and also reset the controller once ES is fully loaded but still cannot fix the issue. I also have two of these I need to set up would I need to repeat everything in Floobs tutorial or just the files that specify the MAC address?
      https://github.com/retropie/retropie-setup/wiki/setting-up-a-bluetooth-controller
      When I try to manually connect I get this error message.ErrorMSG
      An error occured connecting to the bluetoth device (Creating device failed:
      org.bluez.Error.AlreadyExists: Already Exists)
      I went through everthing again but dont see a issue with the files.
      • Dave BD
        Dave B
        • Dave BD
          Dave B
          • Dave BD
            Dave B
            Would it be beneficial to remove my device and rediscover it?
            • Dave BD
              Dave B
              If I undiscover and rediscover it connects but It wont show in Emulation Station
              • Dave BD
                Dave B
                I am able to get it working now on Emulation Station but on reboot it needs to be manually discovered again, I wrote the script that finds the MAC address and make sure it found but it does not seem to be working.
                #!/bin/bash
                sudo bluetoothctl << EOF
                power on
                connect [MAC Address]
                exit
                EOF
                I made the correction and was given a prompt for a pin I set it to 0000
                It seems to be working fine now
                #!/bin/bash
                power on
                exit
                EOF
                Would that be the only change to make two of the same controllers be found on boot?
