    Adventures with ODROID XU4 and RetroPie
    odroid xu4bugsworkarounds
    36 Posts 8 Posters 9.2k Views
      BuZz administrators @yaazzz
      @yaazzz if it works fine, I can enable scummvm for mali targets. Thanks.
      • Y
        yaazzz
        Good morning. I tried to compile Dolphin but it seems I brake the system as I got the following messages :
        lvl0: Error creating SDL window!
        Could not initialize EGL
        lvl0: Renerer failed to initialize!
        lvl0: Windows failed to initialize!
        Before touching anything I would like to get your feedback on what is the best solution to recover.
        • Z
          zerojay
          You upgraded your version of SDL2 to whatever is latest in Ubuntu and therefore broke emulationstation, most likely. You'll have to run the installation again to get the original SDL2 installed.
          I'm not sure why you are compiling Dolphin as I really don't see it being something usable on an ODroid XU4.
          Y 1 Reply Last reply Reply Quote 0
          • Y
            yaazzz @zerojay
            @zerojay said in Adventures with ODROID XU4 and RetroPie:
            Hi, thank you for this feedback. You are Right I don't know why sometimes I am so stupid :) So I tried what you suggest without success. By the way as I didn't reboot after the scumm install please let me check again if it is not the origin of the brake.
            For people having a cloushell please disconnect the disk and cloudshell for the first boot, make :
            apt-get update
            apt-get upgrade
            apt-get dist-upgrade
            apt-get install linux-image-xu3
            poweroff
            Then reconnect USB and connector to the cloudshell.
            • Y
              yaazzz
              I confirm it is working without the !mali flag. Enjoy!
              • E
                Elwro
                Hi,
                I have problems with RetroPie on XU4 too.
                For example, on Ubuntu 18.04, I can't build RetroArch :
                LD retroarch
                obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_find_prev_driver » :
                video_driver.c:(.text+0x54f4) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_find_next_driver » :
                video_driver.c:(.text+0x55ec) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                obj-unix/release/gfx/video_driver.o : Dans la fonction « video_context_driver_init_first » :
                video_driver.c:(.text+0x573c) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                obj-unix/release/gfx/video_driver.o:(.data.rel.ro+0x10) : référence indéfinie vers « gfx_ctx_mali_fbdev »
                collect2: error: ld returned 1 exit status
                Makefile:187: recipe for target 'retroarch' failed
                make: *** [retroarch] Error 1
                ~/RetroPie-Setup
                Could not successfully build retroarch - RetroArch - frontend to the libretro emulator cores - required by all lr-* emulators (/home/odroid/RetroPie-Setup/tmp/build/retroarch/retroarch not found).
                • E
                  Elwro
                  lr-mupen64plus :
                  /usr/bin/arm-linux-gnueabihf-ld : ne peut trouver -lGLESv2
                  Makefile:304: recipe for target 'mupen64plus_libretro.so' failed
                  make: *** [mupen64plus_libretro.so] Error 1
                  Removing additional swap
                  ~/RetroPie-Setup
                  Could not successfully build lr-mupen64plus - N64 emu - Mupen64Plus + GLideN64 for libretro (/home/odroid/RetroPie-Setup/tmp/build/lr-mupen64plus/mupen64plus_libretro.so not found).
                  • E
                    Elwro
                    PPSSPP :
                    cc1plus: warning: unrecognized command line option ‘-Wno-deprecated-register’
                    CMakeFiles/native.dir/build.make:86: recipe for target 'CMakeFiles/native.dir/ext/native/base/PCMain.cpp.o' failed
                    make[2]: *** [CMakeFiles/native.dir/ext/native/base/PCMain.cpp.o] Error 1
                    CMakeFiles/Makefile2:163: recipe for target 'CMakeFiles/native.dir/all' failed
                    make[1]: *** [CMakeFiles/native.dir/all] Error 2
                    make[1]: *** Attente des tâches non terminées....
                    [ 22%] Linking CXX static library ../../lib/libspirv-cross-core.a
                    [ 22%] Built target spirv-cross-core
                    Makefile:129: recipe for target 'all' failed
                    make: *** [all] Error 2
                    ~/RetroPie-Setup
                    Could not successfully build ppsspp - PlayStation Portable emulator PPSSPP (/home/odroid/RetroPie-Setup/tmp/build/ppsspp/ppsspp/PPSSPPSDL not found).
                    • Z
                      zerojay
                      @elwro said in Adventures with ODROID XU4 and RetroPie:
                      Use the ORA image instead.
                      • E
                        Elwro @zerojay
                        @zerojay
                        Ok, thank, too bad.
