    Blue tooth controller won't work properly in emulators
    blue tooth
    2 Posts 2 Posters 412 Views
      gehrig4yanks
      I am using the Pi 3, and I have a GP500 blue tooth controller. I have it properly configured in the menu but when I go to ANY emulator the buttons are not mapped correctly. No matter which buttons I push there is no "start" button nor an "A" button. I have reconfigured it in Retropie and in each emulator individually many times and it is always the same result. Works fine in the menu, but when you select an emulator the only buttons that work are up and down (which are correct) and that is it. Please help.
      • KN4THXK
        KN4THX
        Maybe try resetting the controls all around using this threads instructions:
        https://retropie.org.uk/forum/topic/5069/resetting-controller-configuration/2
        "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
