    1.8TFT SPI 128*160 V1.1 screen not working with RaspberryPi please help :(
    1.8tft spi 128screenraspi zero w
    35 Posts 5 Posters 5.7k Views
    • HexH
      Hex
      Use this as your fbtft.conf
      options fbtft_device name=sainsmart18fb gpios=reset:25,dc:24,led:23 speed=40000000 bgr=1 rotate=1 custom=1 fps=60 width=128 height=160
      and reboot
      • retroprogrammerR
        retroprogrammer
        @Hex Now I have a white screen
        Do I have to change wiring?
        Here is me converting the original Xbox for a case:
        https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
        Check out my GitHub: https://github.com/retro-programmer
        • HexH
          Hex
          just revert it then. change name to fb_ili9163
          I ont know what is causing the color problem. can you post a new picture of how a game like Zelda on Gameboy color looks like ?
          • retroprogrammerR
            retroprogrammer
            @Hex Here is the pictures of Zelda on GBC:https://imgur.com/a/6JHBZ
            • HexH
              Hex
              @retroprogrammer i see in your fbtft.config file you have bgr=1, can you remove it and let me know if that works?
              That should resolve your colour problem
              • retroprogrammerR
                retroprogrammer
                @Hex No still same problem
                • retroprogrammerR
                  retroprogrammer
                  @Hex Is their a way of making the screen a bit bigger?
                  • HexH
                    Hex
                    how about bgr=0
                    The problem is that your blue and red channels are switched and this is the only way to resolve this. If this doesnt work then you will have to try different device names as some device_names dont support the BGR parameter (let me know if you need those).
                    From the author of fbtft:
                    bgr :
                    Set BGR bit (supported by some drivers). Use if Red and Blue is swapped. Default is don't touch.
                    The best way is to buy a new screen that is bigger. Else you could try my Viper frontend, which is in works currently. Even i was unhappy with the performance of ES on smaller screens. Here are some of the photos of my frontend. The screen is 320x240 @ 2.2inch.
                    Gamelist with images
                    • retroprogrammerR
                      retroprogrammer
                      @hex said in 1.8TFT SPI 128*160 V1.1 screen not working with RaspberryPi please help :(:
                      how about bgr=0
                      @Hex bgr=0 doesn't work either, I think the red and blue are swapped around or something, I need to know the device_ names please.
                      • HexH
                        Hex
                        Take a look at this thread. the author also had the same problem and was able to get it resolved https://github.com/notro/fbtft/issues/156
                        • N
                          Nochii
                          I use 1.8TFT that similar the red board one but it use st7735S. I config following the tutorial but no luck the screen keep white. what should I do ; w;
                            juj
                            I recently added support for 160x128 ST7735R display to my https://github.com/juj/fbcp-ili9341 display driver. Perhaps it is close enough to ST7735S that it might work there as well by reusing ST7735R options, if you're interested to hack on it a little.
                            • N
                              Nochii @juj
                              @juj I try this command:
                              git clone https://github.com/juj/fbcp-ili9341.git
                              cd fbcp-ili9341
                              mkdir build
                              cd build
                              cmake -DST7735R=ON -DPI_ZERO=ON -DGPIO_TFT_DATA_CONTROL=24 -DGPIO_TFT_RESET_PIN=25 -DSPI_BUS_CLOCK_DIVISOR=6 ..
                              make -j
                              sudo ./fbcp-ili9341
                              (I use pi zero not zero w)
                              I use https://www.aliexpress.com/item/1-8-inch-TFT-LCD-Display-module-ST7735S-128x160-51-AVR-STM32-ARM-8-16-bit/2055099048.html?spm=2114.search0204.3.30.14dd7e5bb5f8hn&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_5722611_10340_10341_10696_5722911_5722811_5722711_10084_10083_10618_10307_10059_100031_10103_10624_10623_10622_10621_10620_5722511-10620normal#cfs,searchweb201603_11,ppcSwitch_2_ppcChannel&algo_expid=320e54af-4cc8-48be-be2c-2dc33de19d12-4&algo_pvid=320e54af-4cc8-48be-be2c-2dc33de19d12&priceBeautifyAB=0
                              and connect with
                              LED 23
                              SCK 11
                              SDA 10
                              A0 24
                              RESET 25
                              CS 8
                              GND GND
                              VCC 3V3
                              but it does not work what I do wrong? (I quite new to Raspberry Pi)
                                juj
                                Not exactly sure, the initialization does look good. Try checking through the FAQ and Troubleshooting list if anything in there particular might be relevant: https://github.com/juj/fbcp-ili9341#faq-and-troubleshooting . If not, it might be that there's something essentially different between ST7735R and ST7735S that will need to be taken into account. If you find the spec sheets for both, perhaps you'll be able to spot a crucial difference?
                                • N
                                  Nochii @juj
                                  @juj Thank you, I think I should try change the GPIO pin if any progress I will report again :)
