    Pie was running great, now not at all, no gamepads detected...
    help
    30 Posts 4 Posters 6.9k Views
      CJMyers513
      Hey Guys,
      Raspberry Pi Zero
      32 GB Micro SD
      Micro USB to 3 USB outlets and 1 power outlet.
      It was running great for about an hour or so. I got the roms all loaded on and both game pads configed. Then after about 30 min or so, the game pads started not being detected. If i messed with it for a bit, they would work for a minute, then stop. Now, I can't get them to work at all and I've noticed when i boot it up, i see the colored square for a sec or 2. Does this sound like a power issue?
      Please help.
        CJMyers513
        Also, I'm using a micro usb phone charger i had around the house to power the unit.
          SammyBoy
          It's a power issue I had the same issue then what I done was I got the official power supply because my power adapter (a phone charger) had less than 1.0A however the minimum requirement was 1.8A(pi 2) the minimum requirement for pi 3 is 2.5A
            CJMyers513
            thanks for the info. now, running it for that amount of time wouldn't cause any damage to the pi right?
              SammyBoy @CJMyers513
              @cjmyers513 well actually I found out that the pi zero needs 1.2A of power but I'm pretty sure that the raspberry pi will only draw how much power it wants.
                @cjmyers513 said in Pie was running great, now not at all, no gamepads detected...:
                No the time doesn't matter as long as you have the right amount of power. Additionally if you don't want to overheat your pi or get more power get a heatsink or/and a mini fan.
                  CJMyers513
                  @SammyBoy so i was running it with just enough power to run the unit, but nothing else (usb hub and controllers). I wonder why it worked for a short time?
                    @cjmyers513 how many amps is your charger?
                      CJMyers513
                      @SammyBoy 100-240v .2a output 5.1v
                      rbakerR C 2 Replies Last reply Reply Quote 0
                      • rbakerR
                        rbaker @CJMyers513
                        .2a
                        0.2A ??? You will be unable to run anything at all.
                          CJMyers513 @CJMyers513
                          @cjmyers513 out put also .7a
                          • rbakerR
                            rbaker @CJMyers513
                            @cjmyers513 At 0.7A, you will be unable to run anything. You need a minimum of 2.5A, preferably 3A for peripherals.
                              CJMyers513
                              @rbaker i'm trying to upload a photo, but it keeps saying it needs to be less than 1000kb when the photo is less than 400kb, so im not sure. that's what the wall adapter's saying.
                                CJMyers513
                                so basicley, get a raspberry pie power supply then?
                                • rbakerR
                                  rbaker @CJMyers513
                                  @cjmyers513 Any 5V supply that can deliver greater than or equal to 2.5A will be fine. Phone chargers are not recommended as they may not provide a regulated 5V so as soon as you power up, the voltage collapses.
                                    CJMyers513
                                    this is what i'm using
                                    rbakerR 2 Replies Last reply Reply Quote 0
                                    • rbakerR
                                      rbaker @CJMyers513
                                      @cjmyers513 You are wasting your time trying to use that device.
                                      • rbakerR
                                        rbaker @CJMyers513
                                        @cjmyers513 As you are running a Pi zero with peripherals, you might get away with 2A. But 0.7A - it will boot then anything could happen. Most probably, the charger will get hot.
                                          CJMyers513 @rbaker
                                          @rbaker sounds good. I'll get a new power supply. I kind of had a feeling this adapter was going to be a no go. Thanks for all the help.
                                          • KN4THXK
                                            KN4THX
                                            This post is deleted!
