    RetroPie on top of Mint - autostart issue, terminal window
    autostartmint 18
    5 Posts 4 Posters 1.2k Views
      tomeq82
      Hi,
      I dig through the forum but can't find answer to the problem I have.
      I'm trying to build dedicated Linux box since 4.1 RetroPie, recently i've tried 4.3 and Mint 18.3 setup on x86_64 PC. Everytime i'm building the RetroPie from scratch. I did that many times and all the time end with same issue: when I choose to autostart RetroPie after restart I end with overstretched terminal window (more than fullscreen) instead of ES screen. This is problematic as the terminal window cannot be closed - just switched using alt+tab to the ES screen. Now, when you want to have keyboardless setup then this is a problem.
      Any ideas how to solve that? Some edits to autostart script? I went through it but cannot find section which is causing this.
        tomeq82
        Heh, replying to myself but I sort of managed to fix this. I don't know if this is a bug or feature but during autostart gnome-terminal is launched with "--fullscreen" option instead of "--maximize". The first one apparently forces terminal to be on top of any window and that's why ES screen is not.
        Now, it seems to work as expected.
          Clyde
          Thanks for sharing your solution.
            danjohnny5 @tomeq82
            @tomeq82 how did you change to --maximize? Having the same issue on an all in one running Mint+Retropie
              movisman
              Hi,
              I had RetroPie running on Mint for a short time and I didn't need to mess with the fullscreen options. All I did was add a startup delay of 3 seconds to the RetroPie entry. This stopped the issue. I would leave it as fullscreen and try that? I think this happens because if ES starts before X is running it doesn't launch. Not sure though but a slight delay should resolve.
