    Emulate Specific Machine in Retropie MSX
    msxarabic msxal alamiyahax170sakhar
    36 Posts 5 Posters 6.7k Views
      grant2258 Banned
      ok this is going to be a bit technical but it is doable for what you want to do. You can change the machine to what you want but there will be a few steps
      1. start the rom form the command prompt with strace (change your romname and path to what ever rom isint working right to find out what machine it is selecting.
      strace /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-bluemsx/bluemsx_libretro.so --config /opt/retropie/configs/msx/retroarch.cfg "/home/grant/RetroPie/roms/msx/ax370/abc_arabic.rom" 2>&1 | grep config.ini
      open("/home/grant/RetroPie/BIOS/Machines/MSX2+/config.ini", O_RDONLY) = 3
      in this case its picking the msx2+ machine replace that config.ini with the MSX2 - Al Alamiah AX-370 or whatever mx2 config you want for that machine.
      you will get a segfault if one of the bios roms are missing this is a bug it should be telling you this info not segfaulting. So check all the bios filename case is right when changing it
        grant2258 Banned
        i posted a issue on the github page about the segfault bug hopefully that will help some people out with a error when its bios related the user will know.
        You can pick any config you like the .rom extension will always pick msx2+ so just change that config to what you want the config to be. Its not ideal but its how you can make it do what you want to do. The config is just a path it can be any machine setup.
        https://github.com/libretro/blueMSX-libretro/issues/72
          Shinobi
          Ok, Thanks you. I'll try it and tell you the results.
            Shinobi
            In BlueMSX for windows I use MSX - Arabic machine which use three files according to the config file:
            0 0 0 0 84 "" ""
            0 0 0 4 66 "Machines/Shared Roms/MSXAR.rom" ""
            1 0 0 8 19 "Machines/Shared Roms/ARAB1.ROM" ""
            3 2 0 8 23 "" ""
            3 3 2 4 64 "Machines/Shared Roms/NATIONALDISK.rom" ""
              Shinobi @grant2258
              @grant2258 I knew what machine was running from the BIOS name (select + x) screen and choosing your machine, so I replaced the config file for the machine running with Arabic MSX machine, the result was, when you choose a game ROM to play, it just goes Blank and returns again to game ROMs menu. BlueMSX won't allow you to change anything in it.
                grant2258 Banned
                @shinobi said in Emulate Specific Machine in Retropie MSX:
                3 2 0 8 23 "" ""
                you hit the segfault issue you probably getting no error and dont understand why it easy i checked you post before with your roms.
                ARAB1.ROM
                NATIONALDISK.rom
                MSXAR.ROM
                and your config
                0 0 0 4 66 "Machines/Shared Roms/MSXAR.rom" "" * case doesnt match
                3 2 0 8 23 "" ""
                0
                you ms2ar.rom case doesnt match each other
                  Shinobi
                  I played with filenames to make them match, any manipulation to MSX machine resulted in ir-bluemsx not working..
                  Actually I got tired from this, I tried openMSX on Raspbian and succeeded in launching Alamiah AX170 and AX350IIF machine (both Arabic), I put ROM games in (software) folder of openmsx, and when launching the cartridge from openmsx commandline it say (rom not found in this context) .. in the documentatin it is saying that default folder for game roms in (software) .. I 'll post this in msx.org since this is retropie forum...
                  thanks for your help, very appreciated.
                    grant2258 Banned
                    I got it working no problems this way. I did change all my filenames to lower case and the machine files as well to avoid any confusion. Windows wont rename your files properly. I did get it working for me it is your bios filenames causing the problem. You have to change the whole config file not just the slots :). I understand you being fed up with that it is frustrating for some.
                    do youself a favour though make your life easier rename all your bios files to lowercase on the pi machine no matter what emulator your using and change any bios references to lower case to avoid problems
                    cd ~/RetroPie/BIOS/Machines/Shared\ Roms/
                    rename 'y/A-Z/a-z/ if -f;' ./*
                      grant2258 Banned
                      this is the config you should have just paste it in if you decide you want it. This config assumes you renamed all the roms like above to lowercase
                      [Video]
                      version=TMS9929A
                      vram size=16kB
                      [CMOS]
                      Enable CMOS=0
                      Battery Backed=0
                      [Subslotted Slots]
                      slot 0=0
                      slot 1=0
                      slot 2=0
                      slot 3=1
                      [External Slots]
                      slot A=2 0
                      slot B=3 0
                      [FDC]
                      Count=2
                      [CPU]
                      Z80 Frequency=3579545Hz
                      [Board]
                      type=MSX
                      [Slots]
                      0 0 0 0 84 "" ""
                      0 0 0 4 66 "Machines/Shared Roms/msxar.rom" ""
                      1 0 0 8 19 "Machines/Shared Roms/arab1.rom" ""
                      3 2 0 8 23 "" ""
                      3 3 2 4 64 "Machines/Shared Roms/nationaldisk.rom" ""
                        Shinobi
                        Now thank you, because it worked. I renamed all to small letters. It was filenames issue.
                        now my problem is there is no sound. all is good volume is up 100%.
                        I appreciate your help. The reason behind this is that i want my son to use the educational software I used when I was a kid.
                        My son thanks you. although he is so little, but I'm preparing the system for him
                        I wish sound problem won't need formatting since i got alot of systems and roms in my retropie sd.
                          grant2258 Banned
                          no problems I looked at the source it seems i can add system to the cpp file. ill need to test this. Just to be clear if the system is in auto it nearly always defaults to msx+. Ill look at that when i have time if your comfortable compiling c source code ill look into add these arabic machines so you can pick them. Thats for another time though I need to look into this system more. Now you sound issue is it all emulators or just this particular system?
                            Shinobi
                            Sound worked, I forced sound output through HDMI since I use HDMI to VGA adapter.
                            How can I run the MSX without ROM cartridge (without game) .. Arabic MSX got a firmware of BASIC and Drawing program, etc...
                            I try this on my LAKKA SD card too
                              grant2258 Banned
                              just load the rom cart as a game
                              • L
                                lama
                                This post is deleted!
                                  dubamh
                                  Would you please provide a summary of the steps you followed to make Arabic roms works correctly ?
                                  I have same issue and I have read your post many times and couldn't got the corrects steps .
                                  Please support .
                                  Thank you
                                    dubamh
                                    Got it .
